Old 04-13-2006, 08:41 PM   #1
pinggoy's Avatar
Trader Rating: 24 (96%+)
Send a message via Yahoo to pinggoy
Default stucked and stripped hex screw on chassis..
hi i got a t2 and mybe its because i hit the car so hard and that crash might had cause the snugging of my screw so right now i cant unscrew it cause it stuck and now its stripped..can anyone advice me how to take it out without damaging my chassis??its in the bottom plate the screw that holds thw metal part.... thanx
pinggoy is offline   Reply With Quote
Old 04-13-2006, 08:50 PM   #2
I had the same thing happen to my xray. The best way is to drill out the screw. Get a drill that just fits into the threaded portion of the bulkheads and then drill straight down the damaged screw. You may be left wiht the small piece stuck in the threads but these can be removed with some poking around.
Make sure you have put some CA glue on the chassis where the screw sits adn I use a bit of lube on the screw threads when I install them. This should prevent this problem in the future.
Lano is offline   Reply With Quote
Old 04-13-2006, 08:53 PM   #3
Send a message via AIM to rcguy2477
The easiest way is to get the kit from Craftsman that is made to take out screws. It literally takes only seconds to take the screw out using this kit. It costs around $20, but it is much better than ruining a chassis.
1989 Mazda Rx7
greddy t04b, megasquirt ecu, PlX wideband, 12x28x3 fmic, 50mm hks clone wg, ssqv bov, Safc, ss oil lines, walbro fuel pump, tubo intake manifolds, ssac exhaust manifold, 3" dp, 550cc primary/720cc secondary injectors, etc.
rcguy2477 is offline   Reply With Quote
Old 04-13-2006, 09:12 PM   #4
pinggoy's Avatar
whats the name of that kit....i dont really wanna ruin my chassis ... that car is hooking up and it does not bother me right now but i know sooner or later i need to unscrew them for regular chassis clean up...
Old 04-13-2006, 09:14 PM   #5
pinggoy's Avatar
lano,
you put ca on the screw and lube on the hole?? it keeps it from getting the screw stuck??
Old 04-13-2006, 10:11 PM   #6
Originally Posted by pinggoy
lano,
Sorry for not being clear.
Put some CA glue on the chassis where the flat headed screw sits and let it dry. This will seal the chassis and prevent the screw from sticking. I also put a little lube on the threads when I install the steel screws into the alloy parts. If you go to the xray site you will find complete instructions.
Old 04-13-2006, 10:51 PM   #7
http://www.sears.com/sr/javasr/produ...id=00952155000
1989 Mazda Rx7
Old 04-13-2006, 11:46 PM   #8
pinggoy's Avatar
thanx a lot guy for your willingness to help.....im an intermidiate driver now and hoping to hit some races so wish me luck.....again thanx
Old 04-14-2006, 12:01 AM   #9
ottoman's Avatar
R/C Tech Charter Subscriber
The Sears extractor (also sold under other names) works well. I keep it in my pit box and guys are always borrowing it... never found a screw it didnt take out
ottoman is offline   Reply With Quote
Old 04-14-2006, 10:33 AM   #10
Send a message via AIM to acyrier
I use a dremel and a cutting disk. Cut a slot, or pair of slots and use a straight or phillips screwdriver to get the screw out. You'll need to "PRESS HARD" on teh screw head to not strip the slot. I've yet to have to drill out a screw.
The products and places I support.
www.michianarc.com www.facebook.com/michianarc - www.russellrc.com
www.teamtekin.com - www.teamcrc.com - www.teamassociated.com
www.fantomracing.com - www.discountrcstore.com
acyrier is offline   Reply With Quote
Urgent stripped screw help coons88 Electric On-Road 14 02-24-2007 04:46 AM
stripped pinion screw AZNracerx1989 Rookie Zone 3 08-02-2005 11:31 PM
Stripped Screw DIMO Electric On-Road 11 06-07-2005 03:57 PM
stripped screw ntc3freak Nitro On-Road 23 09-21-2004 05:35 AM
Stripped Screw RCDoon Electric On-Road 1 04-01-2003 09:11 AM
