Xpress Arrow AT1
#587
Same. 38, 42 camber plates, and stock setup so far. It's been incredibly smooth and easy to drive on medium-high traction asphalt over 8 different races. Now moving up from 21.5T GT class to 17.5 Stock Blinky on carpet.
Had one carpet practice day and my front spool comes loose all the time. Might have forgotten to tighten it recently, but just wondering why I need to retighten it at all... Feel like design was rushed on this one.
Thoughts?
Thoughts?
#589
Thoughts?
Thoughts?
#591
Battery Brace
Broke my battery brace needed something before Sunday. With some minor Dremel work, I got the Associated TC7 braces (ASC31778) to work. Not bad for $11. I used a short servo mount and screw that I had lying around as a battery fore/aft limiter. So far so good.
#596
R/C Tech Elite Member
Yeah already have the packs as it was the only way to balance the T420 with the LCG kit without coming in at 1400 grams RTR as the mount pushed the battery that far out. Would prefer not to fork out for new packs again! Anyway, slowly slowly, will be taking my time on this and still running the T4 in the interim
#597
I run ultra narrow Arromax lipos on my AT1. The easiest way was to use standard battery mount and cut the 90deg ends off and then use old servo mounts and screwed them into the screw hole that allows the adjustment of forward and backward movement of battery.
#598
#600
sorry Im unable to send photos. the battery mount I used were from AT1 and maybe 10QR I got other battery mount in the kit that was maybe for other Xpress cars. I,ll see if Smokem can put photo on his facebook page
