Xpress Arrow AT1
#559
Took a trip to the Bendigo track today as a warm up for a trophy race in a couple of weeks. Had an issue with the fan mount, the screw worked loose and the fan fell out during a warm up lap. I asked a marshall to unplug the fan so I could attempt the race without it - but nope, the ESC shut down due to thermal protection on the motor sensor. The fan can move around a bit, and as it does it works the screw loose. I'd prefer an alloy version of the fan mount so I can loctite the screw in place, but maybe I'll switch to using a 3rd party mount that clamps around the motor.
Other than that, the car had good pace and felt comfortable to drive. On the last 2 runs I switched from the stock 42 front 46 rear camber link plates to 38 front 42 rear, which felt even better. I was able to push a bit harder with more stability, and improved on my times. According to the club's website, I broke the 13.5T blinky track record for total race time, and missed out on the lap record by 0.05s.
#560
I can only imagine how fast gigaplex's car could have been with my lightening program...It would have been at least 60g lighter...Hopefully Exotek will come out with an AT1 lightening package soon...Later....
#565
#567
I do understand your point, but you forgot about the dcj drives+ rear cvds+ wheel bearings which might add another 44g or more to the mix for a grand total of about 125g or more....125g - 60g = 65g....68g is what I was able to achieve with my car of a different brand, but the logic(aluminum+CF+plastic) is still applicable here: lightest spur gear, ceramic bearings(17g),/ CF driveshaft/aluminum inputs(10g), full aluminum dcj's(4g), aluminum rear axles+ plastic bones(3g), 15g or less rear gear diff(two plastic satellite gears/plastic cross, aluminum screws&outdrives), and 10g or less front spool.....I know the parts will be weaker and costly, but it's the name of the game...Once done you will notice a big acceleration difference eventhough the total weight of the car is the same(minimum weight)...A good cnc machinist is a must here, and, since your car is already very close to winning, it might be worth the expense...Good luck, and happy racing...
#569
Ceramic bearings: Maybe. I don't like using them as wheel hub bearings as they don't handle side impacts well. Some of the drivetrain bearings are odd sizes, my local bearing provider doesn't do some of them in ceramic. Not really worth the effort.
CF driveshaft/aluminum inputs: There is no CF driveshaft option, and the aluminium input options have been announced in the parts list but not released. The weight savings of the CF shaft will be fairly small (less than 5g, I have a TC3 and I've measured alloy vs carbon) and the diameter is so small that the rotational inertia is negligible.
Aluminium DCJ/rear driveshafts: I tried the alloy rear driveshafts - they lasted one race meeting. Not worth the trade off. Front ones don't exist and I wouldn't want to try them.
Rear gear diff: The outdrives are steel, the aluminium ones haven't been released yet. Removing the already plastic satellite gears won't save much weight and will reduce durability.
The main areas of improvement are the input shafts and diff outdrives, swapping out the steel parts for the alloy options when they become available. That'll save maybe 10g
