Xpress Arrow AT1
#526
Sorry if this has been covered but does anyone know if bodies swap between this and the xq10?
Front bumper of course the same but not sure about wheelbase and rear mounting etc.
#528
Thank you, so it appears with the xq10 xsquare setup and horizontal rear posts things could swap back and forth?
#530
Has anybody else broken front drive cups. I,m now on my third, wondering if Im missing anything on assembly. Should they be greased when sliding the drive shaft in ? Only running 13.5t Blinky mmmmm
#532
replace broken drive cup from last meet got two 6min runs before lining up for third run and notice car doing donut and knew another broken cap. No big hits, so only lasted three runs. Seem no one else have same problem, not sure what I might be doing wrong. Running large outdoor track with no barrier to crash into. Unless some sort of binding. Bit lost!!!
#533
#534
It's just a matter of getting in the groove, and not comparing all the wrenching to a belt car...Also, if you use 64p spur gears, choose a brand that is not out of round by much, if at all: it will make gear meshing a breeze...
#535
#536
I was hoping to be able to swap bodies between the two Xpress platforms... was considering gigaplex's solution but I guess I could have both vertical and horizontal mounting holes in the bodies if I use the traditional mounts on the XQ10's. I'm not going to use the X-Square parts.
#537
That sure seems like a fair price at 350
#538
on power
I now blueprinted the Setup from bigdog only the camber link plates are missing as they are still waiting to pass the customs ...
as soon as I have them it is a 1:1 blueprint
unfortunately I did not had the chance to try it out yet, but 'll keep you posted
I also ordered the aluminum main chassis from krazedbuilds yesterday, due to the fact that xpress is still sleeping to develop and produce it . btw this is something I was not used from Tamiya or other brands, that we have to wait sooo long for spares and hop ups to get released. this could be done much better from Xpress. finally a spare Diff is now available from rcmart and hopefully soon from all distributors all around the globe too
So lets wait for the high bite chassis *g* to be delivered. hopefully before November, to be ready for the start of our indoor championship
#539
I finally had the chance to battle my AT1 in a 21,5GT Race last weekend. And Setup from above really gives a good steering car on higher grip. on less grip (morning) still rear was loose, but I was impressed about the handling later on as the grip on track was getting better and better. but as outdoor season is nearly over now, and we're starting indoor on black carpet soon, low grip shall not be the problem there any longer
#540
