Old 04-12-2006, 06:16 PM   #1
Default Motor smell?
After about 10 - 15 minutes of using my rc car I start to smell something like burning rubber. Is this just the brushes fading away? I think it is normal but I really need a second oppion.
Faint is offline   Reply With Quote
Old 04-12-2006, 06:34 PM   #2
xrayaustin's Avatar
Trader Rating: 12 (93%+)
Send a message via AIM to xrayaustin
anything that smells like something burning is never a good sign!!
Www.superiorhobbies.com
2010 cleveland indoor champs and 2011 snowbird nationals 17.5 stock A main winner
xrayaustin is offline   Reply With Quote
Old 04-12-2006, 06:53 PM   #3
tfrahm's Avatar
Send a message via AIM to tfrahm
If you are running 10-15 minutes STRAIGHT, without letting things cool off, you are killing the motor...
Borrow a temp gun from a nitro racer and check the temp of the motor. you normally want to keep it at or below 170 degrees. The worst I've ever seen was a stock sedan motor that came off the track at 230 degrees after a 5 minute race -- the motor was never the same (magnets lose strength from heat, etc.)...
"If you cannot win, make the one ahead of you break the record."
Biff Racing Team #420 (Ah... The "good old days"...)
The local indoor Offroad Track: The RC Race Barn
TLR22-3.0, TLR22T-2.0, TLR22SCT-1.0
tfrahm is offline   Reply With Quote
Old 04-12-2006, 07:01 PM   #4
What if I got a motor cooler and and cooled my motor before running it?
Old 04-12-2006, 07:39 PM   #5
Trader Rating: 32 (100%+)
Send a message via AIM to A. Rhodes
The motor coolers are designed to bring down the motors ambiant temp., not the temp while running. The effects of the motors cooler are gone in 30-60 seconds once you start racing. You can add a fan(s), or cut some coolng holes, but your most safe not running your motor for that long at one time.
Retired from RC....
Quantum - St. Croix - Bass Pro Shops - XPS - Rapala
A. Rhodes is offline   Reply With Quote
Old 04-12-2006, 08:28 PM   #6
Thanks for all your help so far but one more question. Couldn't you switch out motors in between runs? I understand the ESC could get hot but regardless I just want to know.
Edit - Also would a "rebuild" fix the damages from running the motor too long?
Old 04-12-2006, 10:00 PM   #7
tfrahm's Avatar
When/If a motor had been overheated, the impact varies....
Some Magnets are much more tolerant than others (Reedy MVP's always seem to get HOT, but once they cool down, the magnets are as good as ever)...
The most common "damage" is that the brushes get hot and turn a purplish color -- when that happens, they are ruined, as the lubricant in the brush has been cooked out and the copper and silver components have been "annealed" (the metal actually changes it's characteristics)... Over heated brushes MUST be replaced.
Similarly, the comm will turn colors , ranging from copper to brass to red to purple. As with the brushes, this can harden the copper. The heat cycles can also make the comm out of round, as the copper surface and the phenolic center core will expand/contract differently from the heat. Carefully skimming of the comm on a comm lathe can "mostly" revive an overheated comm (the copper may be permanently hardened/changed by the heat). Skimming the comm will be "good enough" for most casual use -- hard core racers would find the results unsatisfactory, however...
Old 04-13-2006, 02:37 PM   #8
hurley081182's Avatar
Trader Rating: 15 (100%+)
Send a message via AIM to hurley081182 Send a message via Yahoo to hurley081182
you smell the rubber from your tires you are going so fast...lol
Old School Stampede=FUN
hurley081182 is offline   Reply With Quote
Old 04-13-2006, 09:12 PM   #9
That is what I thought at first. I must have looked so werid sniffing an RC car
What's THAT smell!? boostfiend Nitro Off-Road 9 05-06-2008 01:26 PM
Ice Competition charger burnt smell Iceracer Electric On-Road 2 04-23-2007 06:09 AM
Funny smell from my Hudy case. . . . cyber3d Electric On-Road 1 12-11-2006 06:22 AM
smell good ??????? tmaxxking Chat Lounge 3 09-30-2006 06:25 PM
Burning smell and smoke from car. Michael Barch Electric On-Road 9 03-12-2006 05:47 AM
