Xray X4F - X4 based FWD car >
Like Tree63Likes
Old 02-13-2023, 10:17 PM
  #91
I need to upgrade to this. But I love my T4F.
raydengt2000 is offline
Old 02-18-2023, 11:48 AM
  #92
First run today. Fortunately the walls at my local club are fairly robust and survived unscathed despite my best efforts.
Gradually improved throughout the day.
The kit springs are a bit soft. Does anybody have any suggestions for brands other than xray that fit. I have amsome associated springs bit they are a little bit too long. The price of xrays own springs is a bit steep.
tortoise 1 is offline
Old 05-28-2023, 10:29 AM
  #93
DirkW's Avatar
The X4F'24 has been released:
https://teamxray.com/x4f/2024/en/
DirkW is offline
Old 08-12-2023, 04:23 AM
  #94
Trader Rating: 24 (100%+)
Lightbulb
Does anyone know if/when XRay will release an aluminum chassis for the 2024 X4f?
Red5Ltr is offline
Old 09-17-2023, 04:02 AM
  #95
Stephtruc's Avatar
Hello,
A idea of ratio for indoor racing on high grip ETS carpet with blinky HW esc and 17.5 HW G4 motor ?
Thx
Stephtruc is offline
Old 09-28-2023, 03:48 AM
  #96
Originally Posted by tortoise 1
Found the cause of the clicking.
The belt pulley is a slightly loose fit on the square section of the spur gear hub. Have added some grease which deadens the sound,
I was in this rabbit hole a few months ago. Yes adding grease does deadens the sound of the click. Best solution is to replace the 5x1 rubber o ring. alternatively you may use a tiny amount of blu tack in-between the spur gear holder and the center pully. Not ideal but works to remove the click completely too
Cheers,
AM
++SGS is offline
Old 04-01-2024, 07:48 PM
  #97
sloanedogg's Avatar
Any word on the '25 X4F? Looking into the 24 but might be worth holding off.
sloanedogg is offline
Old 06-02-2024, 12:13 AM
  #98
h2e
h2e's Avatar
https://www.redrc.net/2024/05/xray-x...d-touring-car/
Notable changes:
- slightly more front biased weight
- motor moved by 5mm
- carbon upper bulkheads at rear
- upper arms now full plastic instead of bling-but-silly-expensive CFF parts.
- single bellcrank steering
- another iteration of attaching battery and servo together.
Of course many X4'24 parts from bulkheads and suspension.
h2e is offline
Old 06-02-2024, 12:58 AM
  #99
gigaplex's Avatar
Notable changes:
Might be worth using those upper arms on the regular X4, the carbon inserts keeps breaking for a lot of people.
Kapryiath likes this.
gigaplex is offline
