Old 12-11-2006, 09:44 PM   #31
WRXTC's Avatar
Originally Posted by MK_Arbiter
How do you remove the sheilds off bearings?
I would like to know the answer to this also, all my bearings have metal shields and I cannot see a way to remove them for cleaning.
WRXTC is offline   Reply With Quote
Old 12-11-2006, 10:35 PM   #32
Mr. Shookie's Avatar
R/C Tech Charter Subscriber
Send a message via AIM to Mr. Shookie Send a message via MSN to Mr. Shookie
Originally Posted by Fervidsea
Just picked up some Boca Cermaics, Ultra seals. They have grease in them I believe, roll smooth but not really "free". They are supposed to be maintence free. Am I gonna see much improvement by cleaning them with a bearing blaster and motor spray then re-oiling them? Or should I leave them be?
The Ultra seals are designed to be forever sealed.
I use them exclusively in my Truggy or any nitro vehicle.
For Touring Car I would have gone with the Secret Weapon bearings as they come with light oil only.
The good thing about the ultra seals is that after you break the bearings in (run them a ton (i.e. 30-40 times)). They will be nice and free. No need for lube and they will keep everything out of the bearing.
I have had the same set of bearings in my Jammin CRT for almost 6 months and all I do is check them for wear and clean off the dust. No re-lubing and no removal of seals. Maintance free and loving it.
But for on road metel sheilds seems to be the choice.
Boca has the 99cent sale that gets you nice bearings at an affordable price.
To remove the metel sheilds there is a very small c-clip on the outer edge of the bearings seal. You use a new xacto blade with a very sharp tip. You gently pry the c-clip out and set it aside. Then the sheild should pop off, clean out the rubbage and relube, put back the seal and the c-clip. Check for free spinning and binding. If the bearing is either, check again and if you can not fix, replace the bearing.
Hope that helps,
-Shookie <><
All who love the LORD JESUS I praise with you.1 Cor 10:31
Team HOLY Rollers (Team Manager)
The Church is a Hospital for Sinners not a Museum for Saints.
RcTech Feedback <>< RC Tech Subcriber #92
Mr. Shookie is offline   Reply With Quote
Old 12-12-2006, 05:59 PM   #33
Fervidsea's Avatar
The bearings I purchased are ultra seals however they have metal shields not rubber...
Question is, Can they be cleaned now to remove the grease to add oil?
Fervidsea is offline   Reply With Quote
Old 12-12-2006, 07:56 PM   #34
akura2's Avatar
Send a message via AIM to akura2 Send a message via Yahoo to akura2
anybody use the Integy bearing cleaner?... it's a blue battery-operated box that vibrates the bearings in their solution to clean then better
akura2 is offline   Reply With Quote
Old 12-12-2006, 07:59 PM   #35
akura2's Avatar
edit**
Old 12-13-2006, 06:35 AM   #36
Nicadrauspro4's Avatar
Originally Posted by D_o_S
Well, how do I go about doing it? I heard that you should dump the bearings into a container, cover with WD40, shake, then empty the oil and repeat until the oil is clean. Then lube with some ball bearing lube (I have some LRP Blue factor).
Should I follow this procedure?
There were thread before with the same topic. Just search for it in this site and you will find more answers there.
works1200.weebly.com
nicadraus-lamborghini.weebly.com
Nicadrauspro4 is offline   Reply With Quote
Cleaning ball bearings? JSY Rookie Zone 19 08-19-2016 06:55 AM
Ball Bearings @sd Malaysian R/C Racers 30 04-12-2007 07:55 PM
ball bearing cleaning andy_b22 Rookie Zone 5 04-09-2006 10:08 PM
Ball Bearings Kennedy Australian Racing 18 10-10-2003 10:52 PM
Where do you get your ball bearings? TambokGT Nitro On-Road 6 03-10-2003 01:30 PM
