Like Tree1529Likes
GT12-RT
Old 03-25-2022, 08:12 AM
  #61
Originally Posted by mrreet2001
The mid west is running the USGT (or similar) detuned 21.5. (which are close to a hot 25.5). I find it interesting you guys went with such a fast motor.
Oh trust, me, it is not fast at all. Very comparable to a 21.5 current generation.
Carnage9270 is offline
Old 03-25-2022, 08:15 AM
  #62
Rastaracer's Avatar
Originally Posted by Carnage9270
Not sure who this question was directed at, but up in Seattle we've decided to run the HW 17.5 fixed timing. We made this call to just eliminate motor war arguments that inevitably crop up. The HW 17.5 runs just like a 21.5 normal motor (yeah it's pretty de-tuned). It also adds a ton of weight to the car and eliminates the need to even mention a weight rule haha.
But we are starting this up here to use the class as a bit of a stepping stone into 12th scale and it's working fantastically. With the FT motor, a fixed gearing and rubber tires....the class really becomes something that won't overwhelm a new racer or even an old one just getting into 12th scale. They can focus on driving and how setup affects the car.
thanks for the response, I see it definitely is a stepping stone for 1/12.
Here at our club there is no other rule for motors other then it needs to be 21.5, and the gearing is open too. We only have 3-5 guys at the moment, 1/12 17.5 LMP is the most popular class tho
Rastaracer is offline
Old 03-25-2022, 08:22 AM
  #63
R/C Tech Elite Member
mrreet2001's Avatar
I guess it's a matter of perspective. Compared to a hot 17.5 it is slow. Compared to a USGT motor (or equivalent) it's fast.
mrreet2001 is offline
Old 03-25-2022, 08:42 AM
  #64
Billy Kelly's Avatar
the one time I’ve seen GT12 run. There’s was about 1.2 seconds slower then the 17.5. Laps of 7.1 vs 8.4 second laps. I’m still a bit off that pace
I’m assuming they were using the USGT motor. But didn’t see them to confirm(damn auto spell)
Billy Kelly is offline
Old 03-25-2022, 09:06 AM
  #65
I’m assuming they were using the USGT motor. But did see you confirm
We ran a mixture of 21.5 and the HW FT for a while and really didn't notice a lot other than the 21.5's having a lot more grunt. A really good 21.5 puts the HW behind. Those HW FT motors are pigs...which is perfect for this class imo.
Could be a product of the fixed gearing too....we ran 72/40 at the time. I might add, that gearing is a bit of a problem with the CRC cars.
Billy Kelly likes this.
  #66
mrreet2001's Avatar
delete
Old 03-25-2022, 12:27 PM
  #67
gwc
What setups are people running? Toe, Caster, Camber?
On super high bite black carpet at Apex RW HW21.5 motor with 30deg timing 100.8 roll out 2deg toe 4deg caster 1deg camber.
mrreet2001 and Kruss45 like this.
gwc is offline
Old 03-25-2022, 02:03 PM
  #68
If your having gear problems try the RW spur gears. I have a 66 spur on my CRC GT12 and have fitted a 67 pinion. These gears of course won't take the small CRC balls but work just fine as spool gears or use 1/8" balls if you run a diff.
Canuck, BullFrog and gwc like this.
sweems is offline
Old 03-25-2022, 02:36 PM
  #69
oldrcr's Avatar
Trader Rating: 46 (100%+)
the gear problem on the crc has to do with running a 72/40 fixed gearing. The crc motor mount doesnít allow this ratio to mesh. If you go with a bigger spur and pinion to get the same ratio, the bigger spur gives a noticeable advantage. So far, that chassis is the only one that has that issue.
-a
oldrcr is offline
Old 03-25-2022, 02:57 PM
  #70
My bad, didn't realize your issue was going to less gear. Most people work to get to larger rollouts not smaller but I can see your issue. Hopefully your local race director will change the gear so all makes can be included. I'm guessing that Awesomatix drivers are in a similar spot, their car has a really small adjustment window for gear selection,
sweems is offline
Old 03-25-2022, 04:00 PM
  #71
That is why we ditched the Gates original fixed gear rule. We had a 56/72 setup which didn't fit the A12 nor the X12. Lets guys have some tuning options and learn.
old_dude is offline
Old 03-25-2022, 05:25 PM
  #72
FWIW He had supply issues.
I get that there are supply issues, but Scotty could reply to people. I want to support this class and his efforts, but a little customer service... an update of any kind... would go a long way.
MC Hamilton is offline
Old 03-26-2022, 04:53 AM
  #73
mrreet2001's Avatar
I feel you on that. Granted I am very thankful he does, but itís confusing to me that I have never had an issue with communication with him and many others have.
MC Hamilton likes this.
Old 03-26-2022, 08:39 PM
  #74
Default Getting started...
New to electric on road and thinking GT12 is the right place to start. Sold all my nitro onroad equipment 12 years ago but ready to get back into the hobby.
I like the xray x12. I have looked for used options a little bit but my preference is to build up a brand new kit and learn the details of the chassis along the way. Here are photos of the setup I'm planning.
The club near my house is running the 21.5 in these. Below is a screen shot of my wish list so far. What am I missing? Im mostly unsure on servo. Body, wheels, charger, will be determined later. Am I missing anything else? What would you recommend and/or change?
BrentK is offline
Old 03-27-2022, 03:00 AM
  #75
I like the M17 radio myself and the white carbon battery from Trinity. Great servo. The HW 209.00 I believe has the better battery protection (in case you put the plugs in wrong).. Bodies and tires are your choice.
BullFrog is offline
