Like Tree737Likes
GT12-RT
Old 02-16-2023, 02:49 PM
  #661
Team EAM
Trader Rating: 79 (100%+)
Originally Posted by RKeasler
True... I discussed this point with a person close to the subject and he said basically the one tire rule is the catch all, hard to police the other, not much point in trying
I guess ROAR added that about no skimming. But as you said hard to police what happens outside of the track if people want to do it. The limit of one set of tires kinda limits how much you can do anyway because if someone does it too much and wears the tire down then they dont get another set! The way it is seems to have policed itself the last few races that have done it.
EA
RKeasler, vafactor and Kruss45 like this.
EAMotorsports is offline
Old 02-16-2023, 03:39 PM
  #662
gigaplex's Avatar
EA
How does one take it outside the track? When we do controlled tyre multi-day events, you have to hand the tyres back in before leaving.
gigaplex is offline
Old 02-16-2023, 05:07 PM
  #663
cobrajet's Avatar
Originally Posted by Nego
head over next month to beachline , they will be running on road once a month, gt12 foam it's one of the biggest classes. We will get you going for carpet and asphalt setup, as far as running rubber tires if we get the turn out they will run it.
Definitely trying to get out there soon even if just for a practice session. Trying to get a coworker into racing also.
Nego likes this.
cobrajet is offline
Old 02-16-2023, 05:37 PM
  #664
Team EAM
Not how its done in the US. Tires are marked with tamper proof labels/markings but thats it End of day you dont turn them in.
EA
Old 02-16-2023, 07:58 PM
  #665
gigaplex's Avatar
EA
So anyone can goop or skim or do anything else to the tyre if they take them home. Labels generally only work on the rim, what's stopping someone from taking the tyre off the rim and replacing it with something else?
gigaplex is offline
Old 02-16-2023, 09:50 PM
  #666
trackdesigner71's Avatar
If you're going that far with the SJT tires to get an advantage,you've got a problem is all I'll say
davidl and simple like this.
trackdesigner71 is offline
Old 02-16-2023, 10:28 PM
  #667
DirkW's Avatar
When we marked tires the last time, we did it with both labels and a splotch of some garishly colored nail polish that covered both rim and tire.
DirkW is online now
Old 02-17-2023, 04:14 AM
  #668
Removing the tires and replacing them would be an extreme effort. I have mounted them and that side is hard by hand.
old_dude is offline
Old 02-17-2023, 05:16 AM
  #669
R/C Tech Elite Member
mrreet2001's Avatar
I find they get weird and inconsistent if I don't scuff them occasionally. I lightly scuff them by hand with a gravity tire file once or twice a race day. Keeps them feeling new and not like an old lizard. Apparently I have a problem.
gigaplex likes this.
mrreet2001 is offline
Old 02-17-2023, 05:56 AM
  #670
gigaplex's Avatar
Soaking them overnight in an additive banned by the track is pretty darn easy though. And while not directly relevant to this thread, it's pretty easy to do swaps with TC tyres using acetone. Sounds like EA was implying that tyre impounds aren't a thing in general over there.
gigaplex is offline
Old 02-17-2023, 06:38 AM
  #671
All this discussion about the rubber tires? If your going to try to remount those tires like Old Dude said -have fun!
BullFrog is offline
Old 02-17-2023, 09:35 AM
  #672
mrreet2001's Avatar
I think this thread has gone off on a control tires in general tangent. At least I hope so. I have seen the machines Scott using to build these things. I doubt people are bringing these to the hotel rooms.
Old 02-17-2023, 10:23 AM
  #673
If this isn't the place to ask, then I can move my question elsewhere so apologies in advanced.
I purchased a used XRay X12 '22 which was built to the factory specs, and came with a GT12-RT setup (1S ESC, 21.5 motor, GT body, SJT tires).I haven't run 1/12th scale in 20 years and never ran on black carpet until last week, but I was experiencing traction rolling. Is this something that happens with these cars if you dont drive them a certain way? Also, on a high grip black carpet track using SXT, I found that I was basically able to keep the throttle pegged wide open about 99% of the time, only letting off approaching a hairpin to let the front settle for a millisecond before getting back to full throttle. Does that mimic what others experience, or am I way down on power or something? It reminded me of the old 4 cell NiMH days but with 100000% more traction.
tuxkilla is offline
Old 02-17-2023, 11:00 AM
  #674
before things get back on track, I was referring to people taking the rubber off and replacing it because that is the most extreme thing someone could do to get an advantage in that class
Old 02-17-2023, 11:48 AM
  #675
simple's Avatar
1. I've been running the X12'21/22 for the past couple years on black carpet - I apply a coat of CA glue to the front outside bead of the tires - have not had a single traction role since.
2. A good place I've found to start gearing is the smallest Spur you can fit on your setup (ex:I use a 66 on the AMX gear diff axle) and 10 teeth off for the pinion (56)... I then tune to whatever track is setup, depending on layout or length of straight for a balance of max speed and acceleration. The tricky part with the XRAY cars is finding a spool or differential that will combine with the spur and pinion you want to size.
Nego likes this.
simple is offline
