GT12-RT
#167
I for one cannot answer your question. Never done that type of comparison. I run mostly 1S (1/12th and WGTR). I am that old school fast guy who knew what to do to make rocket fast brushed motors. Been back in RC for three seasons and until four months ago was buying team edition motors and was afraid to open them up out of fear of screwing them up. Since December, I have purchased a Mini-Pro dyno, bought the Sky RC 2s dyno and built a resistance dyno. After hours and hours of testing/adjusting and learning how 21.5 and 17.5 motors respond, I find that I set most motors around 50 degrees of timing, trying to balance torque and efficiency. I think I could have saved a ton of time and money knowing that I could buy a team edition motor, crank the timing to 50 degrees and be close enough for club racing.
Maybe someone else is out there who has spent more time building motors for both 1s and 2s?
#168
#169
I have the Dyno and I can tell you that I have gone to lower timing settings across the board. Torque is king on our smallish indoor tracks and depending on the motor the low end torque disappears fairly quickly as you turn up the timing. My GT12 class uses a fixed timing motor (USGT Spec) and it is a 30-32 degree motor. Funny thing is I own that same motor in the TOUR oval series spec which is set at 45 degrees. There is a significant torque difference in the lower range of the motor. That doesn't hurt a oval guy on most tracks as they are typically higher in the rpm range.
Almost all of my motors are between 30 and 38 degrees. Variations in rotor strength and stator design by brand have affects on the timing sweet spot.
In the near future, I will have a heavier flywheel for my Fantom Dyno. I expect much better data from the increased inertia of that wheel. The aluminum wheel doesn't load the motor as much (it was fine on brushed motors) so the prime data was only about .5 seconds worth.
A solid characteristic for those without a dyno. Peak power happens at near 50% of peak no load rpm. The motor also has peak torque at near zero rpm and near zero torque at peak rpm. As you turn up the timing the power peak moves to a higher point. Watts is a straight torque and RPM calculation. So what you are doing is shifting the torque curve with the timing. The sweet spot is getting the torque curve flatter without killing the bottom end.
#170
For what it’s worth, the Fantom flywheel dyno is the only one that seemed particularly useful to me. IMO, unloaded free spinning data doesn’t relate very well to what the motor experiences in the car and on the track.
So I’m guessing that with unusually low timing settings you are also liking very tall rollouts???
using your dyno findings (which make good sense to me), what kind of timing and rollout settings might you recommend as starting point with on a decent fresh 17.5 motor?
#171
It's really hard to nail anything down for a specific person unfortunately. Too many factors are at play to give someone sound advice. Driving style can completely change how you run a motor. Some motors like low timing and lots of teeth, some like high timing with few teeth...then there's all the motors in between. The only way to really know how your motor performs is to put it on the track and run some clean laps and check the times throughout a run....yes, it takes a long time. But again, I have to circle back...driving style can take an extremely well set up motor for one person and be a dog to the next. It's all these attributes that keep people racing, whether they like to admit it, or even realize it, or not.
#172
#173
I also will have steel flywheels for the Fantom Dyno available once we confirm the prototype.
#175
#177
#179
If you are going to buy one get the light weight the .80 is a brick.
BLZ60909-05 BLITZ Lightweight P1 1/12th On-Road Car Clear Body ( - Michael's RC Hobbies (michaelsrchobbies.com)
#180
I’ve been focusing more on my gt12 A12 lately. It’s a great class at apex. Some of the best people I’ve ever had the pleasure of racing against and learning from. If you’re in the area and looking for some of the most fun people to race against then apex is your kinda track
