Old 04-10-2006, 09:05 PM   #1
sukh's Avatar
Default armature
I have a peak 8 turn motor with the v2 end bell, I wanted to know if I could take the armature out and put it in my brood atlas can that originally has a 19 turn arm?
Thnx……..
sukh is offline   Reply With Quote
Old 04-10-2006, 09:32 PM   #2
Got Xray?'s Avatar
Send a message via MSN to Got Xray?
Default Fine
Yeh that should be fine mate.....u can use pretty much all endbells with any can or arm.
!xray!
Got Xray? is offline   Reply With Quote
Old 04-11-2006, 06:04 AM   #3
sukh's Avatar
ok cool, i thought because the peak comes with the v2 endbell that i might have a problem putting that arm in the brood because that comes with the normal laydown style brushes.
Old 04-11-2006, 07:36 AM   #4
You are not planning to run that 8T arm with the laydown brushes of the Atlas are you?
vassago is offline   Reply With Quote
Old 04-11-2006, 07:50 AM   #5
sukh's Avatar
i wanted to run the 8t arm that came out of the peak and put it in the brood atlas, the peak had a v2 end bell and the brood has laydown brushes. the only reason i want to do this is because i ruined the v2 end bell in a crash and the arm is still good and i dont like the v2 too much so i thought i would throw it into the atlas can.
Old 04-11-2006, 08:28 AM   #6
Don't run it with the Atlas endbell, laydown brushes will ruin an 8T arm within minutes.
You can use normal standup brushes, checkpoint or whatever. Just not laydown.
Old 04-11-2006, 08:33 AM   #7
sukh's Avatar
ok thnx, i won't run the 8t with laydown brushes, just wanted to know why it would ruin it though?
Old 04-11-2006, 08:38 AM   #8
Can't tell you exactly other than that laydown is made for high-turn and low power arms like 27T en 19T.
The brushes are too wide causing the comm to burn up.
Armature help Nautilian Electric On-Road 4 11-16-2006 02:29 AM
wtt for TI armature Team_ass.4ever R/C Items: Wanted to Buy 1 03-13-2005 08:53 PM
New Armature Or New Motor? crACkeD ChaSsiS Electric On-Road 20 02-21-2005 02:52 PM
armature [email protected] R/C Items: Wanted to Buy 0 02-07-2005 08:35 AM
Fantom Armature Nipple R/C Items: Wanted to Buy 2 11-01-2004 04:38 PM
