Schumacher Mi8
#61
Desk verdict
Well I bought a carbon version right when the shop opened their books, and built it last night. Here's my desk verdict.
+ great tips in the manual. One better reads them carefully
+ great assembly order. I kept my fingers clean for quite long
+ great fit and finish. I didn't remember Schumacher has all plastic parts removed from the parts tree already and flashing removed
+ doweled parts fit together with no play and the drivetrain is super free.
+ Very little play when new. replaceable balljoints
+ Seems to be a robust design. All carbon parts look designed with thought.
+ great to work on (I tested drivetrain cleaning) once built, also great idea with press in nuts.
+ seems to have a good torsional stiffness range with the options provided. Great simplicity with bushing on topdeck.
+ suspension parts are very stiff, so no wheel misalignment under load.
+ beautiful shocks and diff/ spool but (-) heavy diff.
+ great lower shockmount, easy to use pliers for the ballhead.
- Battery holder design doesn't allow for shimming the parts, if you need more protection.
- large distance battery to motor (18.5mm per kit)
- steel hardware is robust, but makes for high unsprung mass (36-38g rear-front). E.g. the rear driveshafts are Alu with many other brands.
- rear toe links inner ballheads are only accessible with ball hex driver. As they are loctited, that might strip the hex
- long and wide chassis (compared to traditional Tamiya designs, there is more potential for chassis dragging). Even the Mi5 had a more compact chassis.
- diff/pulley fences are a pain to mount
- turnbuckle war as with an awesomatix. I had to squeeze almost all of them as they were overly tight. Using pliers also scratches the beautiful black parts.
- wheel hex and ballcup O rings (i.e. on the lower arms) difficult to remove.
None of the negative points are really bad. I am very happy with the build and look forward to an eventual test drive (still some time in the future).
#68
Steel or aluminum diff outdrives?
#69
Have you accidentally cut a bit of the diff outer with pliers? Belt could catch on that?
#70
#72
I prefer drilling speed holes in the diff case.
#73
Pretty heavy, but what oil was in it ???
Gear diffs: 25g mi8, 21g tc6, 26g specR , 25g mtc2, 29g to 31g tamiya tb05/shaftdrive,etc,......Who has the lightest gear diff ??? Anybody with a 15g gear diff ? I know from experience that a 10g difference will affect laptimes...Chime in....
#74
Interesting discussion about a 2 gram diff weight difference....NOT.
We like to know how this Mi8 goes together and even more important how it performs in the hands of an average driver.
#75
It goes together smooth as silk - see my desk verdict above. The 25g diff weight is ok considering it's the only 40T diff out there, and alu.
