3racing Cero Ultra 2022 >
Like Tree238Likes
Old 10-21-2022, 10:10 AM
  #211
moparSRT's Avatar
Originally Posted by jammin684 View Post
Is this Cero Ultra going to replace the S64 or am I safe running the S64 a bit longer?
s64 not going anywhere, it will continue as kit and parts.
moparSRT is offline
Old 10-21-2022, 11:21 AM
  #212
Trader Rating: 45 (100%+)
Thanks for the quick reply.
jammin684 is offline
Old 10-25-2022, 06:59 PM
  #213
Super Moderator
Marcos.J's Avatar
Trader Rating: 235 (100%+)
Originally Posted by moparSRT View Post
Chassis is not drilled for shorty packs, easily done with a drill bit if u want to run a shorty
easy just need to use a 2mm spacer under to clear the pinion . Stock height blocks some of the pinion access
mr.rev likes this.
Marcos.J is offline
Old 10-25-2022, 09:59 PM
  #214
jo_er86's Avatar
Does AMX caster doodles fit the Cero?
jo_er86 is offline
Old 10-26-2022, 06:28 AM
  #215
Super Moderator
Marcos.J's Avatar
they should my friend uses them on his MTC2 and the cero has the same hub
Lonestar and jo_er86 like this.
Marcos.J is offline
Old 10-27-2022, 12:33 AM
  #216
Taz_S's Avatar
Look sweet but wish they came with the holes done already.
Taz_S is offline
Old 10-27-2022, 07:54 AM
  #217
Super Moderator
Marcos.J's Avatar
same here but honestly I took less than 5 minutes , drill and a countersink bit
Marcos.J is offline
Old 10-27-2022, 04:37 PM
  #218
Any news on an aluminum chassis for carpet?
Robbob likes this.
topfuelhobbies is offline
Old 10-27-2022, 05:55 PM
  #219
Super Moderator
Marcos.J's Avatar
I got a feeling someone is working on it (hint hint)
Taz_S likes this.
Marcos.J is offline
Old 10-27-2022, 09:29 PM
  #220
Marcos, do you have any opinion on the Cero vs the XQ10?
I am curious about working on the cars if one is more a PITA than the other. Can you get a faster run in the Cero?
Xrayray is offline
Old 10-28-2022, 04:29 AM
  #221
Super Moderator
Marcos.J's Avatar
I’ll be at the track tomorrow
Marcos.J is offline
Old 10-29-2022, 05:54 PM
  #222
Default Nice
We need them for black carpet asap
Old 10-30-2022, 05:17 AM
  #223
First run yesterday at "The Gate" post Halloween Classic. Older black carpet which is normally lower grip but post big race not bad. Kit build setup with heavier sway bars. Car was smooth as butter set up as for the USGT class. My best qualifier would have put me 5th. in the "A" at the Classic. I haven't run USGT much before so that impressed me and several others.
I believe that those heavy bars actually hurt it but I didn't have time to change them. My reason for them was I typically prefer them on my cars. Observation and feel was the car wasn't into the track as much as it could be all around. Next run will have lighter bars as a new starting point.
Taz_S and Marcos.J like this.
old_dude is offline
Old 10-31-2022, 08:04 AM
  #224
Race report for last 2 weekends
Setup for VTA
Weight 1430
Converter to Mid belt
Race 1 - Thunderdome
med to high grip black carpet
Flex screws 3 in rear, 2 in front
Stock Setup
Qualified P2, Finished 3rd
Car performed really well for Q1 and Q2, When traction started to go up for Q3 and Main, it started to lift in the middle of the sweeper with a few gentle traction rolls. I kept it under control by being a slower and being more gentle with the car thru the sweeper. I wasn't sure if this was a VTA tire issue (Mid Life tires) or a chassis issue. Will need more time in high traction to get the car dialed in better although my gut is to much flex and the aluminum chassis would help.
Race 2
GRRC
low to med grip Black Carper
Qualified P1 finished 1
Track normally starts low grip and at Q1 and by Q3 and mains moves to med grip. In Practice, the car had a strong push, similar to the last time I raced at this track. I decided to lower the roll centers front and rear (went from 2mm to 1mm on the lower arms ball studs) to get the car lower in the corners. This was a night and day difference and the car came alive. I ran my AMX (VTA Setup) as a bellwether for comparison, both cars performed equally. There are still a few tweaks I need to work on, like improving low speed corners, I just need some more time with it. Also note that in practice the car was very responsive to how many flex screws where in the upper motor plate attaching the Front upper deck. I ended up running 2 in the main, but traction was still going up, a better choice would have run all 3 screws.
Overall - I like this car - responds very well to setup changes. I am not 100% sold it needs an aluminum chassis for VTA, but with the higher cornering forces of TC on black carpet I would expect it to be a requirement to compete.
John
DrFelter is offline
Old 10-31-2022, 08:47 AM
  #225
Super Moderator
Marcos.J's Avatar
ran the car at my local track this past weekend , and started with the kit set up but wasnt too happy with it with the low to medium traction. made a few changes and got the car to match my laps as my MI8 and MTC2 at this track(same layout ,tires,electronics and body) for the price cant beat it . Had a couple of track excursions but no issues with any of the parts. Here is what I have so far. Racing this weekend at Valkaria Raceway. i ran the motor in the front and Drop was measured at the axle.
File Type: pdf
DavidNERODease and Tuf like this.
Marcos.J is offline
