124019 Motor Pinion >
124019 Motor Pinion
Like Tree2Likes
  • 1 Post By Xrayray
  • 1 Post By glennhl
124019 Motor Pinion
Old 12-31-2021, 12:13 PM
Default 124019 Motor Pinion
Does anyone know what size the set screw is on the motor pinion? WLToys did a wonderful job by filling it in with some sort of glue which I melted most of it out with my soldering iron. I feel like its a 1.5mm, but its not grabbing good and I dont want to strip it. 2mm is definitely too big.
StellarFusion is offline
Old 12-31-2021, 01:51 PM
1/16 is the next size up from 1.5
I wouldn't try anything other than quality machined/hardened tools for removing small hexes, they will strip using standard Allen wrenches.
trx-1racer likes this.
Xrayray is offline
Old 12-31-2021, 03:06 PM
I agree. Thanks
Old 01-01-2022, 11:30 AM
No9
No9's Avatar
Trader Rating: 17 (100%+)
It's probably imperial so maybe a 1/16. I could be wrong but an imperial equivalent of 1.5mm is slightly bigger.
No9 is offline
Old 01-01-2022, 08:46 PM
Trader Rating: 16 (100%+)
1/16" x 25.4mm/inch = 1.5875mm so the 1.5mm is slightly smaller than the 1/16" hex driver.
glennhl is offline
Old 01-01-2022, 09:00 PM
Heat the crap out of that pinion before trying to unscrew it. Little torch lighter works great
bratan is offline
Old 01-01-2022, 11:37 PM
No9
No9's Avatar
As stated in my post.
No9 is offline
Old 01-02-2022, 09:10 AM
Sorry, I misread your post.
No9 likes this.
glennhl is offline
