X-ray X4 can't take larger pinion gears? >
Like Tree3Likes
  • 1 Post By CNEPACE
  • 2 Post By Marcos.J
Old 11-17-2021, 05:38 PM
Default X-ray X4 can't take larger pinion gears?
Switching from Awesomatix to a new X4 to run USGT. On my AMX car I was geared 56/80 and it worked great for our track. The smallest spur I can find for the X4 is a 92. But that's not the problem when I went to put on my 56 tooth pinion, it hits the top plate. Has anybody else ran into this problem? Obviously don't want to modify the top plate. What gearing are you guys running in usgt with the X4?
CNEPACE is offline
Old 11-17-2021, 06:04 PM
HenryC's Avatar
I have been running 57/80 in my T4'21 for USGT. I did a little dremel work on the top deck to get the 57 pinion to fit on the X4.
HenryC is offline
Old 11-17-2021, 06:06 PM
Trader Rating: 16 (100%+)
I would think it's imperative that you find a smaller spur than 92 teeth. Will any non-Xray spurs fit the X4?
glennhl is offline
Old 11-17-2021, 06:09 PM
Regional Moderator
disaster999's Avatar
As stated in the manual, you can use a non xray spur gear, you just need to shim it 1mm on the pulley to clear the top deck
disaster999 is offline
Old 11-17-2021, 06:19 PM
Okay so I put my 80 spur on there just using the 1 mm shims. Then the 56 pinion barely rubbed the top deck so I just went down to a 55. Problem solved!
glennhl likes this.
CNEPACE is offline
Old 11-17-2021, 06:22 PM
Good to hear it. I had a similar question a while back when I was putting together the car. I had a Kawada spur laying around that is used for pan cars and all the holes lined up. That told me that any spur from Kawada, Kimbrough, Robinson, Roche and Serpent would work.
Sabin is offline
Old 11-17-2021, 07:24 PM
Super Moderator
Marcos.J's Avatar
Trader Rating: 229 (100%+)
There’s a X4 thread already
mrreet2001 and gigaplex like this.
Marcos.J is offline
