CK25AR 1/12th car kit from Team CRC
#226
I just picked up an XTi. I just need a parts list to change it from transverse to longitudinal.
#227
if you have an xti it would have started life as a narrow chassis but you need to know if it's an xti that's been converted to transverse or an altered ego. The normal transverse can be run inline with the top deck and side spring brace with the cell cut out but the altered ego would need all the carbon changed.
#229
Would an Xti that's already converted to transverse be considered an Xti WC?
#230
Xti stock chassis (inline)
Xti transverse chassis (PN 32580)
Xti Altered Ego chassis: PN 3326
Xti Black Aluminum Chassis 33571
Xti WC chassis PN 3357
And there was an Xti molded chassis (not sure if this was ever for sale)
There were also two lengths of rear pod plate, so you had about 20mm of play in the overall wheelbase you could put in the car, and 2 or 3 different pod top plates before they made the "low profile" rear slider pod.
Sufficiently confused yet?
#231
I'd say so. Since you listed the part numbers for those revisions and mentioned the slider pod, that makes the one I have an Xti WC.
With that established, what do I need to do to make it a longitudinal layout so it accepts my extremely slightly longer lipos?
#234
Well, I don't need a kit to go from inline to transverse, I need something to go from transverse back to inline.
#235
Save yourself time and money, get a GT12 2s if you can. The difference in height in the batteries is 18 vs 25mm.
EDIT: Here is one of what you need:
https://www.amainhobbies.com/scale-r...0-wht/p1447384
#236
#237
I have the chassis (3258), the short links (3280) and the posts for the front shock mount (1737). I do not have the top deck for mounting the front of the shock (32581). I think I have a different upper deck that will work, but it isn't the original Xti part. Chassis $45, posts $5, links $5. If you do 2 cell, I have that post as well.
#239
There is a significant difference between a 2s pack that is the size of a 1s, and a 2s for other cars. You will be wasting your time trying to fit that massive battery in the pan car chassis, it is much taller and won't fit under the Xti shock mount.
