Old 12-19-2002, 04:05 PM   #1
fasterdanu's Avatar
Cool tip's with comm lathes
any posts about comm truing hi performance tips or stuff for first timers.
fasterdanu is offline   Reply With Quote
Old 12-19-2002, 06:52 PM   #2
-CriMinaL- |RC's Avatar
Send a message via AIM to -CriMinaL- |RC Send a message via Yahoo to -CriMinaL- |RC
When skimming the comm try to take off as little as possble..
when the 3 slots open up throw away the arm because its on its last legs
-CriMinaL- |RC is offline   Reply With Quote
Old 12-19-2002, 07:04 PM   #3
The info I have gotten in the past is once a comm reaches .270 in diameter,it can`t be cut smaller without risking it spinning apart in the motor.
saints1115 is offline   Reply With Quote
Old 12-19-2002, 07:07 PM   #4
that could be true...
not sure though, but yes once comm reaches certain size the segments wil fly off and damage the motor
Old 12-19-2002, 07:20 PM   #5
mike_Webb's Avatar
Send a message via AIM to mike_Webb
I think Big Jim recommends .260 or lower and you will damage your Bit and you could throw a wind.
mike_Webb is offline   Reply With Quote
Old 12-19-2002, 08:57 PM   #6
Tom
Tom's Avatar
u can kill ur bit if u take to little of and dont let it bit in a bit
.270 is what trinity say on web site i think
Tom is offline   Reply With Quote
Old 12-19-2002, 09:28 PM   #7
dtm
dtm's Avatar
Send a message via ICQ to dtm
fasterdanu- It is better to cut the comm more often than leaving the comm until it is "pear" shaped before cutting. For 8-9T motor this is around 4-6 packs (kinda depends on brushes as well).
If you consider one marking (on the Hudy) as one cut.....then, in general, if you need more than 3-4 cuts to clean up the motor each time, you should consider cutting more often.
dtm is offline   Reply With Quote
Old 12-19-2002, 09:38 PM   #8
What happens if you don't have a HUDY? What do you use to judge?
Sydewynder is offline   Reply With Quote
Old 12-19-2002, 09:40 PM   #9
Manticore's Avatar
R/C Tech Charter Subscriber
twister suggested to go by half or quater marking
Manticore is offline   Reply With Quote
Old 12-19-2002, 09:42 PM   #10
unknown's Avatar
Send a message via AIM to unknown
let me ask this question...
do you guys have your own comm lathes? or does your local track/hobby shop have ones you can use?
unknown is offline   Reply With Quote
Old 12-19-2002, 09:50 PM   #11
I have my own.
Old 12-19-2002, 09:52 PM   #12
Markings? What markings? I guess Orion doesn't believe in markings.
Old 12-19-2002, 09:58 PM   #13
Manticore's Avatar
use your dremel to put some marking on the knob !
Old 12-19-2002, 10:02 PM   #14
After I Dremel mark my Comm Lathe, you motors will be the first ones I'll do.
Old 12-19-2002, 10:10 PM   #15
Manticore's Avatar
I will let you do my johnson !
comm lathes BDRMBULLY Rookie Zone 5 05-03-2007 12:56 PM
Help with comm lathes TL_XXX-S_racer Electric On-Road 56 12-28-2005 12:23 PM
Comm Lathes RCNitroDude999 Electric On-Road 3 02-12-2005 06:06 AM
Automatic Comm Lathes Kennedy Australian Racing 3 02-04-2004 01:22 AM
Comm Lathes Dan the Man Australian Racing 34 04-24-2003 06:18 PM
