Old 11-02-2005, 10:08 PM   #151
killer89's Avatar
Trader Rating: 41 (100%+)
Send a message via AIM to killer89
Originally Posted by Stevietd14
I need some advice...
For my entire RC life I have been goin with a buddy and borrowing his lathe.Now he is getting out of RC so I am forced to invest in a lathe or pay $3/cut at my LHS.I race mostly stock with some 19t now and then.I cut my stock motors after every 7-10 runs, and I was wondering what lathe would be best for me?Do I need to invest in a diamond bit, or would a carbide work just as well.I don't have a lot of $ so I was thinking of buying used.Are there any major or common problems that occur from using a lathe a lot(besides bit wear).Like, Would A used lathe have any noticable differences in cutting(not just the bit), between a new one.My buddies lathe was a cobra, and I became very familar with it so I was looking for a Cobra lathe.Any suggestions?
Thanks in advance.
Steve
get your buddy's lathe... if hes getting out of rc, then he should be selling his stuff right?
killer89 is offline   Reply With Quote
Old 11-02-2005, 10:18 PM   #152
fathead's Avatar
Originally Posted by danjoy25
Has anyone tried using the lathe below? Can I assume that it cuts from left to right.
I have this lathe and it cuts real nice with the diamond bit, never had a problem with it
Slavich Design
fathead is offline   Reply With Quote
Old 11-03-2005, 04:51 AM   #153
Trixter's Avatar
Please don't underestimate the Cobra lathe, and I think that Stormer had it on sale with diamond bit for $159.00. I've been using it for about 7 years and it is still running strong!
Slash 4X4, Bone stock and trying to keep it that way.
PRO MATCH BATTERIES.....THANKS JEFF !!
Trixter is offline   Reply With Quote
Old 11-03-2005, 06:28 AM   #154
SpeedBump57's Avatar
Originally Posted by primusblowsgoat
I have this lathe
http://www.hudy.net/xhudy/products/p...5&kategoria=61
and last year i believe i baught the wrong bits for it cause they cut like doo doo butter.
Im about to buy a new bit or 2, probably a couple cheap carbide ones of ebay and maybe a diamond bit off ebay.
My question: what do i get? AR4? AL4?
I cant remember what i baught last year.
Try here http://www.mcmaster.com./ I think the part number is 3367A131
You want grade C2
Single-Point Carbide-Tipped Tool Bit Lh, Style #Al-4, Grade C-2, 1/4" X 1/4" X 2"
Hope this helps
SpeedBump57 is offline   Reply With Quote
Old 11-06-2005, 02:19 AM   #155
Drewdc90's Avatar
The Cobra lathe is good value for money although you have to supply your own motor. You can purchase a cheap 540 Tamiya or Johnson motor and run these at around 3.5 to 4 volts. The diamond bit is the better value option and will give a much cleaner CD type finish and last a lot longer as the carbide bit will only last about 20 cuts ($5 to be resharpened). You don't want to have to replace a shot comm due to a shit bit
Drewdc90 is offline   Reply With Quote
Old 11-06-2005, 12:28 PM   #156
killer89's Avatar
I resharpened my carbide bit with some diamond files i got from someone on here and now it cuts BEAUTIFULLY! looks just like a CD when I get done...
comm lathes BDRMBULLY Rookie Zone 5 05-03-2007 12:56 PM
Help with comm lathes TL_XXX-S_racer Electric On-Road 56 12-28-2005 12:23 PM
Comm Lathes RCNitroDude999 Electric On-Road 3 02-12-2005 06:06 AM
Automatic Comm Lathes Kennedy Australian Racing 3 02-04-2004 01:22 AM
Comm Lathes Dan the Man Australian Racing 34 04-24-2003 06:18 PM
