NEW LRP SPHERE COMPETITION BRUSHLESS
Just curious if anyone has run one yet. I heard it is now going to have a CAP attached to it as well as be able to run lipos. Is it any better than the Novak GTB?
I heard this has no reverse. Is that a fact? The GTB has reverse built in so why no reverse for this one? But the LRP runs cooler. I like LRP ever since.
No reverse allows them to use less FET's in it's construction. Less FET's means less internal resistance which means more volts to your motor. For most racing, the use of reverse is not allowed anyway.
If you haven't seen this Associated Electrics page, make sure to check it out.
I think most people still use brushed motors to race. It would be ashame to exclude one big market that buys brushless - rich and loaded bashers that want reverse.
Another thing - sphere competition got TQ in modified as well, Leino and Levanen was not able to beat it . Unfortunately driver had a bit of bad luck during the finals...
If you go with sphere, you wont regret it
The Sphere comp has the possibility to run Lipos with n automatic cut off if voltage of the lipo droops....
Of course it's possible to deactivate this cut off, which should be done if you use normal nimh cells. If not there might be the danger that the speedo "thinks" your "lipos" are low at the end of the race... i don't believe anyone wants that....
I had the possibility to compare the Sphere Comp/4-Star combo directly with the Novak Combo on track, i tested together with a friend. He's looking forward to get his new Sphere Comp asap...
Originally Posted by JanisK
This weekend I had my first race with shpere competition + 4 star motor in 1/12. Well.... IMPRESIVE. The motor was runing so smooth and powerful, and it felt just like a brushed, even better
5 STAR`s !!!
Oooo
My
God
Oooo
My
God
Originally Posted by jarkko
Perhaps necessary to mention that Christer Andersson who took TQ ahead of the "euro champs" had in his car a 5-star motor wired to the Sphere comp. Some of the other guys used 4-star motors and there was a clear difference in speed.
Oh, when do we/normal people gonna get 5 star?
What motor would you recommend using in a T4 truck on a medium track?
Recommend the Neo 1 Star or if you insist 2 Star Neo.....
Sphere Competition Review Here
Hi Guys and Girls
I did a tech review of the Sphere Competition here...
http://www.12thrc.com
Cheers
Mark
Cheers
Mark
