New Lathe prep????
Old 04-06-2006, 02:17 PM
Default New Lathe prep????
I just picked up Hudy Lathe with v blocks for a killer deal. My question is, before I use it, I have heard that some of you send out your new lathe to a company that bascially blueprints it. I guess you would call it. Go threw it and make sure where the comm turns on and where the bit meet are square or something like that.. Can anyone explain more about this to me and who provides this service. Thanks
What about diamond cutters? Hudy is about $86 recommend any others
tunnelhead is offline
Old 04-07-2006, 07:52 AM
Never heard of such a thing. I really don't think your going to have any problem with a Hudy lathe.
I don't use a diamond cutter. They're easily damaged and I can buy a lot of carbide cutters (at $4 each) for the price of one diamond.
Lano is offline
Old 04-07-2006, 08:08 AM
the hudy lathe is one of the best out there so all you should need to do is make sure there is no play on any of the sliding parts but that they still move fairly free and smooth with out any binding.
im no lathe expert,but ive never heard of having one sent out to have it "blueprinted".
Derek K is offline
Old 04-07-2006, 08:13 AM
Anthony.L's Avatar
Trader Rating: 36 (100%+)
Out of the box the lathe is ready to mount the bit and start cutting. No adjustments needed.
Anthony.L is offline
Old 04-07-2006, 05:24 PM
vaiogeek's Avatar
I use an 8 x 12 model lathe to cut my comms instead of a hobby comm lathe. The model lathes do have to be adjusted to ensure there is not slop and that everything is true.
You shouldn't have the same problem with a comm lathe unless it was dropped or something.
Mainly they would ensure that the v blocks are truly perpendicular to the cutting head and that there isn't any slop in the head.
vaiogeek is offline
Old 04-07-2006, 07:13 PM
POOKYT's Avatar
I have been told the same thing. Somebody out there could shed some light on this please.
Brant
POOKYT is offline
Old 04-08-2006, 06:32 AM
You should be able to take it to a local machine shop to get everything squared up. I would cut a comm on it first and see if it needs adjusting (measure the top and bottom of the cut to see if their is a difference); chances are it is probably fine.
BobbyDoyle is offline
Old 04-08-2006, 06:48 AM
POOKYT's Avatar
Thanks Bobby!!!
Brant
POOKYT is offline
Old 04-08-2006, 04:12 PM
Trader Rating: 40 (100%+)
The hudy lathes are actually 'keyed' to the cross head, and the v blocks are machined in pairs, so there is no adjustment needed to have it cut straight...
brians11 is offline
Old 04-08-2006, 04:37 PM
cut a comm with it first and measure the diameter of the comm at each end.
if its the same don't mess with it. if one end measures a few thousands smaller than one end then try to align the cutting head.
baih is offline
