Old 04-10-2006, 11:03 AM   #121
Anders Myrberg's Avatar
Originally Posted by 51
Anyone know how the weather held up for the mains?
Just talked to Joel. Sun and cloud at the race. But the track itself was never realy warm or hot. There was nobody practice today due to rain. Weather report say sun for tomorrow, but that does not help Joel or Viktor, as there plane leave early tomorrow morning.
Next up: LRP Masters
Anders Myrberg is offline   Reply With Quote
Old 04-10-2006, 11:13 AM   #122
Eirik's Avatar
Hello Ed,
If you look closely you will see he's using 4mm hex in the rear w/1.0mm spacer and I think it's a 5mm hex up front w/no spacer.
This will give a 188mm front trackwidth and 189mm in the rear with the suspension blocks they used.
Eirik is offline   Reply With Quote
Old 04-10-2006, 11:15 AM   #123
R.Ellis's Avatar
the weather was ok on saturday and sunday with the occasional sun break, but for the most part cloudy and cold in the morning, and a slight drizzle on sunday before the 3rd round of mains....., but the track really never got warm to benifit the tires, and there were alot of complaints about the tire selection as well, but Rheinhard will be tough to beat, not one mistake through all qualifications and finals, also Orion was testing a new endbell that worked very well, and also testing with 6x1 motors, also they had a radar gun, and Marc was pulling 45 MPH in the strait....
R.Ellis is offline   Reply With Quote
Old 04-10-2006, 11:21 AM   #124
Martin Crisp's Avatar
Originally Posted by Eirik
Unfortnately I am not there, wish I was!!
Anyway, the biggest difference is the use of larger bearings (5x10) the bearings are further appart as well. This will support the axles way better and give more cornerspeed. The bearings also last longer!
I know they dremmel the hub down 2.0mm so the ballstud will be at the same height as stock w/spacers.
I think the suspension pin height is the same as stock, but the upper camberlink will be slightly shorter, maybe 1.5-2mm
You will need to redrill the pin hole with a 2.6mm drill bit and use the axles from the "old" 415
I always use this modification, my car just feels better with it!!
Hey Eirik,
I use the front HPI steering knuckles for the same reason in terms of axel support and bearing size. I considered the rear at one point, but felt it was too much work to get to fit right. This is also why I like to old suspension because of the bigger bearings etc, but with a weight penalty.
M
Martin Crisp
Power-Story.com | LearnSetup.com
Martin Crisp is offline   Reply With Quote
Old 04-10-2006, 11:28 AM   #125
Eirik's Avatar
Hello Martin!!
It's really not that much work, took me about 25 minutes
You should really try it, my car was really good after I did this and there is less maintainance
I really like the old suspension as well, but only for carpet with rubbers!
On asphalt the LW suspension seems to carry more cornerspeed and it does not work the tires so hard (less overheating)
This is what I have found with my car anyway....
Old 04-10-2006, 11:37 AM   #126
Hello Ed,
can you know which suspension blocks they used front and back.
Tamiya
Much More Racing
LRP electronic
Futaba
Speedtechrc
trf racer is offline   Reply With Quote
Old 04-10-2006, 11:39 AM   #127
Eirik's Avatar
Not 100% sure, but I think B-A front and XB-D in the rear.
This is what I have been using lately and it works really good!!
Old 04-10-2006, 12:16 PM   #128
Scho's Avatar
Send a message via MSN to Scho
Originally Posted by redneck15
GO HOT BODIES CYCLONE!
Incase you diddnt know... its already over mate
Scho is offline   Reply With Quote
Old 04-10-2006, 12:25 PM   #129
Eirik,
I am not that talented with the drill....but it is worth a try Thanks.
Martin Crisp
Old 04-10-2006, 12:26 PM   #130
Originally Posted by R.Ellis
...Orion was testing a new endbell that worked very well, and also testing with 6x1 motors, also they had a radar gun, and Marc was pulling 45 MPH in the strait....
Yeah Baby! Congrats Marc.!
Martin Crisp
Old 04-10-2006, 12:36 PM   #131
TryHard's Avatar
Hello Ed,
Yup, your right Eirik. Didn't see the light blue spacer
cheers
Ed
| THard.co.uk | Xray | MuchMore |
Old 04-10-2006, 12:36 PM   #132
Shop Owner
nnick's Avatar
R/C Tech Charter Subscriber
Send a message via ICQ to nnick Send a message via MSN to nnick Send a message via Yahoo to nnick Send a message via Skype™ to nnick
Hello,
Just returned home and have added some more pictures. Since the camera wasn't mine I'll have pictures from Sunday tomorrow
Pictures can be found here
Nick
Nikolakopoulos Nick
RC RING
The #1 source for all your electric needs www.rcring.eu
Enjoy RCing....
R/C Tech #82
IRT #123
Don't practice until you get it right. Practice until you can't get it wrong
Team Xray T4'17, Team Xray X10'18, TOP Racing Rebel
nnick is offline   Reply With Quote
Old 04-10-2006, 12:48 PM   #133
so with 0deg hubs thats still 3deg.u use that outdoors?
Tamiya
Much More Racing
LRP electronic
Futaba
Speedtechrc
Old 04-10-2006, 12:57 PM   #134
Eirik's Avatar
Yes, with todays hot motors, 3deg. rear toe inn is very good!!
Also, I have found when using a spool, running 3deg just works better, more steering off power and very stable on power!!
Old 04-10-2006, 01:02 PM   #135
wow 3 deg outdoors,most ppl was running 2 outdoors here and 2.5 indoor.
what you use indoors 3.5?
3 seesm alot but i will test it.
are they the old white spring or the new ones but yellow coloure?
Tamiya
Much More Racing
LRP electronic
Futaba
Speedtechrc
2006 IFMAR 200mm NITRO Touring Worlds on TV RCTVLIVE Nitro On-Road 0 08-28-2007 06:58 AM
2006 Worlds - Italy cyclone Electric On-Road 1743 07-29-2006 12:46 AM
IFMAR 1/10 EP TOURING WORLDS 2006 - ITALY MSB Electric On-Road 7 05-24-2006 09:36 PM
2006 ISTC / 1/12 Worlds, Italy. Simon A Electric On-Road 65 02-08-2006 12:38 AM
2005 1/8th On Road IFMAR Worlds in Italy (9/3-9/11) jeffreylin Racing Forum 1 08-17-2005 10:20 PM
