Old 04-12-2006, 01:03 PM   #196
sosidge's Avatar
They are ferrite clamps (or whatever you would rather call them), same as you see on consumer electronics to suppress rf interference.
Been experimented with for a while now in RC, don't seem to be as popular now as they were a couple of years ago, but Much-More have them if you want to try them out.
Old 04-12-2006, 01:56 PM   #197
Default CONGRADULATIONS!
I just wanted to congradulate Marc, Andy and Masami for their great 1-2-3 finish at the Collegno "Worlds Warmup" event.
Judging from the many photos posted - it appears that the PROTOform Mazda 6 was clearly the favoured body. It looks like 9 out of the 10 A-main bodies used were Pf Mazda 6 bodies. (from what I could see the 7th place finisher used an Accord body)
Thanks again guys! - I'm really looking forward to attending the IFMAR Electric TouringCar Worlds in July!
Dale Epp - PROTOform
daleepp is offline   Reply With Quote
Old 04-12-2006, 02:40 PM   #198
Never mind the little clamps! check where his motor sits!!!!!!!! someone has been busy with mans best freind the DREMEL!!!!!!!!!
Nick Simpson is offline   Reply With Quote
Old 04-12-2006, 03:52 PM   #199
Andrew_Carter's Avatar
Send a message via MSN to Andrew_Carter
What are you on about LOL!
Thers no dremel work there mate!
L8rs
ToniSport | Yokomo | GavGraphix | MHP
Andrew_Carter is offline   Reply With Quote
Old 04-12-2006, 05:34 PM   #200
R.Ellis's Avatar
Hara as well....Ride Accord
R.Ellis is offline   Reply With Quote
Old 04-12-2006, 05:49 PM   #201
Chris Adams's Avatar
Anyone that can fully explain this then go ahead. What is the reason behind all of these guys running the wing as far back as possible?
TEXASEOS.net, RcAmerica, Xray, Hudy, Protoform, Orca, Avid, 2mm Designs, Ulti Tires America
Texas EOS 2018!
Chris Adams is offline   Reply With Quote
Old 04-12-2006, 05:52 PM   #202
Super Moderator
Marcos.J's Avatar
Trader Rating: 182 (100%+)
in big tracks the place it as far as back as possible and for short tracks they bring it in closer
Old 04-12-2006, 05:54 PM   #203
Could you explain why? I remember seeing a picture of Peter Robinsons car from the Reedy race and his wing was all the way back and that is not that big of a track.
Texas EOS 2018!
Old 04-12-2006, 06:25 PM   #204
Martin Crisp's Avatar
congrats Dale!
Martin Crisp
Power-Story.com | LearnSetup.com
Martin Crisp is offline   Reply With Quote
Old 04-12-2006, 06:53 PM   #205
carkillaii's Avatar
who has the vids?
carkillaii is offline   Reply With Quote
Old 04-12-2006, 06:54 PM   #206
floodo1's Avatar
Send a message via ICQ to floodo1 Send a message via AIM to floodo1 Send a message via Yahoo to floodo1
yeah i was gonna be amazed that hara would run anything other than ride accord
how do hara's corally style plugs work with the v2 motor? i never realized that was possible before! did they add the female part onto the motor or something?
what is the difference between the new and old MSX rear bulkhead? i cant find any side shots of the new one...is it lower CoG? from the top pictures it looks like the bulkhead now sits primarily below the center shaft (layshaft, whatever) height, and bumps up to accomodate the bearings of the center shaft, is this true?
floodo1 is offline   Reply With Quote
Old 04-12-2006, 06:55 PM   #207
floodo1's Avatar
almost forgot, what springs is hara using?
Old 04-12-2006, 06:57 PM   #208
RobS's Avatar
I would imagine that they plug directly into the endbell. With the heat these motors make if they just soldered a female connection to the endbell it would just melt off...
Rob Say
Action Hobbies Kingsville
"In racing you never really lose. You either win, or learn."
RobS is offline   Reply With Quote
Old 04-12-2006, 07:19 PM   #209
alana07's Avatar
Trader Rating: 52 (100%+)
Send a message via MSN to alana07
the wing was moved back for more stability, moved forward for less stability (easier for the car to rotate)....
没有最好,只有更好!!!
alana07 is offline   Reply With Quote
Old 04-12-2006, 08:51 PM   #210
beerbarron's Avatar
Anymore info about the Kyosho team and what places they attained?
beerbarron is offline   Reply With Quote
2006 IFMAR 200mm NITRO Touring Worlds on TV RCTVLIVE Nitro On-Road 0 08-28-2007 06:58 AM
2006 Worlds - Italy cyclone Electric On-Road 1743 07-29-2006 12:46 AM
IFMAR 1/10 EP TOURING WORLDS 2006 - ITALY MSB Electric On-Road 7 05-24-2006 09:36 PM
2006 ISTC / 1/12 Worlds, Italy. Simon A Electric On-Road 65 02-08-2006 12:38 AM
2005 1/8th On Road IFMAR Worlds in Italy (9/3-9/11) jeffreylin Racing Forum 1 08-17-2005 10:20 PM
