Roche Rapide P12 Evo2 1/12th Competition Kit
#211
Where is the us spec kit available to purchase?
#213
So no one has it yet😔
#214
Looks nice....
#216
#219
#222
R/C Tech Elite Member
#223
not sure everyone knows what your talking about. why don't you share the parts list. i'm sure the parts are also available at - Roche RC USA
330107 - P12 Kingpin
340034 - Upper Arm Eyelet its only available with the upper arms as well
310201 - Lower Pivot Ball you can also use the ones from the old car if you can find them - 310004
530017 - M2.5 E-Clip
2x 18-20mm Turnbuckle.
You will need to flip the Aluminum Upper Caster Block from the outside to the inside of the Aluminum Front Lower Bulkhead. See the example below under the spoiler.
Spoiler
Note - This washer stack made the steering super aggressive! My actual shim stack is 4.5mm above the steering knuckle and 1mm above the top most pivot ball.
#224
so i just built the kit to the manual and the lowest droop setting i can get is like 5mm and that is with the shock being the shortest it can be. the only way i can get 1 mm of droop is to move the shock mounting position forward, is this correct or am i doing something wrong
#225
