1 1/2th Tires and Wheels
looking for supply of 1 1/2scale wheels and tires, actually looking for Yellow Wheels, also donuts only of purple stripe spec, or blue stripe control, Can mount them myself.
normal US suppliers seem vauge or out of stock, Have some Contact spec on the way from A main, would like other sources please. |
I get premounts from CRC or Genesis RC or Ulti. As far as yellow rims, you can always soak your tires/wheels in lacquer thinner after they have worn out to get the wheels. And if they are white wheels, you can dye them in boiling water using yellow RIT dye. Then you can buy just the foam donuts from either CRC or Ulti and mount them on your dyed rims using contact cement.
At least that's what we did in the old days. |
Originally Posted by glennhl
(Post 15822178)
I'd call Frank Calandra at CRC and ask him if he will sell the spec stripe tires as donuts.
Just dye the whole tire in yellow.
