Need recommendations for sidewall gluing guide
Location: A step closer to where I need to be a step further from where I was
Try Gravity glue guides 57-59mm I think .... I have a tire rotation jig that spins it for gluing.
The easiest way to side glue tires for me is to buy the gravity rc glue bottle with the tiny steel tip. You can pinch the tip with some plyers and get a slower flow of glue for more control. I leave my car on its side and glue the sidewalls while rotating the tire fitted to the car. Using the side of the steel tip to control application as I rotate the tire slowly. I also use gloves while doing this and have a rag to catch any accidental spillage. You can also use 180grit sand paper to manually sand off and excess.
BS Works makes some killer glue guides to help mark your tires
BS Works 1/10 Wheel Glue Guides
Motiv/Gravity's glue bottle with the steel tip to lay the glue down
https://www.teamgravityrc.com/online...ty-3-p62224834
and then I used the Lynxtuff Tire Glue Carousel to use to spin my tires
https://www.discountrcstore.com/Lynx...l-p/lnxtgc.htm
Then I use kicker to help set it:
Put the tires on the car, put the car on a little stand. Maybe remove your pinion gear so the wheels are easy to spin. Clean the tires off with some motor spray or brake cleaner.
Use the Super Thin store brand CA, and Q-tips. Load up the q-tip with the CA, you will need it a little soggy. While spinning the wheels, paint the tire sidewall with the CA, as if it were ink. Eyeball it so that the glue layer comes up to about 1-2mm below the scuffed surface of the tire. Throw away the Q-tip, as it will start to smoke.
This gives the easiest, cheapest, most even glued touring sidewalls I have ever had. It also keeps the flex in the tire sidewall, because the glue is so thin, and better handling.
I think it is about time the tire companies start selling pre-glued sidewall tires...It will save us alot of headaches for the first few laps, eventhough we will need to reglue ourselves....
So it does stiffen the sidewalls?
No, it adds no structure
This technique we use for 12th scale tires is useful in Touring as well
GT12 Racing
GT12 Racing
At one race the grip got very high, to where you didn't have to lift in the sweeper, and to test the glue I drove it into the corner and just twitched the steering wheel to the lock. I could see my car lift the inside tires about a half-inch off the ground... then settle. You know its working when you can't traction roll the car on purpose.
