Old 04-05-2006, 06:04 AM   #1
uniquexme's Avatar
Send a message via MSN to uniquexme Send a message via Yahoo to uniquexme Send a message via Skype™ to uniquexme
Default ho
i just read from somewhere that the diff have to be so tightened so that it doesn't move in the opposite direction. u know wat m saying? d diff that comes with my yokomo kit are already assembled, so i didn't make anymore adjustment on it liao. however, i just found out tat it needs to be so tightened that when u the right rear wheel, the left rear wheel should move in the same direction, not in the opposite. so is this the case?? pls help.
uniquexme is offline   Reply With Quote
Old 04-05-2006, 06:27 AM   #2
Matt Howard's Avatar
when you turn one wheel the other wheel should move in the opposite direction, that's what a differential does. You want the diff tight enough that it doesn't slip, meaning the the diff gear moves and the wheels don't, that's bad and will melt your diff gear.
Official member of The Guild of Calamitous Intent and proud supporter of Conjectural Technologies.
Serpent S411 LE kit #192
RCTech #361
Matt Howard is offline   Reply With Quote
Old 04-05-2006, 10:17 AM   #3
t4m1y4niac's Avatar
some people make their diff so tight...to get the "push" from their car when out of the corner..
SABRE S4 by TOP RACING....
t4m1y4niac is offline   Reply With Quote
