Like Tree2214Likes
Xray X4
    Hide Wikipost
Old 09-12-2023, 09:53 AM   -   Wikipost
R/C Tech ForumsThread Wiki: Xray X4
Last edit by: R Dodge
XRAY X4'22 Helpful tips & setups
Tips:
Installing the hex on the driveshaft - Make 100% sure you have the flat spot lined up on the axle with the cutout in the hex as shown in the manual. If you do not do this, it will make disassembly so much harder. The flat spot is there so you can fit a flathead screwdriver in between the shaft and the c-clip to pop it off when you want to remove the hex. Also, when removing the c-clip I would recommend pointing it down into your pit mat/towel so the clip does not go flying and disappear.
Assembling the upper arms - Make sure to grease the threads on the camber screw (302640). This will make assembly and camber adjustments much easier. Also, when adjusting camber you want to make sure you hold the upper arm so it does not twist while you turn the screw.
Droop - It is important to remove the shocks. All team setup sheets will show droop settings with shocks removed. Simply detaching them from the arm will do. This is a change from how we set droop in the past.
Setups:
**If the super mods on this forum were actually right, and handled things correctly, they would not have gone back and deleted all the posts to hide things
***And since they are in the deleting mood now, they might as well go ahead and just delete all the images of the setup sheet, as originally requested via private comms.
Print Wikipost
Old 08-20-2021, 11:14 AM
  #46
R/C Tech Elite Member
mrreet2001's Avatar
Originally Posted by Riketsu
From the same thread:
"Specialized pan car". Sure thing, by your definition a FWD is also a Touring Car.
Well Im just going to put a LeMons Proto body on my T4 and make it a Pan Car.
gigaplex likes this.
mrreet2001 is offline
Old 08-20-2021, 11:15 AM
  #47
mrreet2001's Avatar
Originally Posted by anthonyscardina
I personally have nothing better to do at the moment
Soon we will have 3 pages of what is a pan car.
Old 08-20-2021, 11:16 AM
  #48
Riketsu's Avatar
Trader Rating: 34 (100%+)
Same here.
asirolli likes this.
Riketsu is offline
Old 08-20-2021, 11:19 AM
  #49
mrreet2001's Avatar
A FWD Touring Car is still a Touring Car.
Smokeyr67 and gigaplex like this.
Old 08-20-2021, 11:54 AM
  #50
ChrisP's Avatar
Originally Posted by simple
Wow!! 3 pages of speculative conjecture and it hasn't even been released yet. Well done
Brace yourself...weeks and weeks of this to come!
simple likes this.
ChrisP is offline
Old 08-20-2021, 11:56 AM
  #51
Dan the Man's Avatar
Trader Rating: 41 (100%+)
Neither do I. This is even more entertaining than the usual T4 release five page horse puckey, because no-one is even sure that the X4 IS a touring car.
Carry on, I'm bored at work tonight
simple, mrreet2001 and asirolli like this.
Dan the Man is offline
Old 08-20-2021, 12:16 PM
  #52
Trader Rating: 16 (94%+)
Of course the Xray X4 is the new touring car. Look at the naming standards for all the other kits, X12, X10, XB2, XB4, SCX, XB8, XB8E, XT8, XT8E, XT4, GTX8, GTXE, RX8, RX8E, X1. Everything has an "X", and since the only car offered with a 4 immediately following a letter was the T4, logic says that X4 is the new touring car, and one that is likely to be different and new enough that Xray decided it warranted dropping the "T" and getting in line with the current naming standard.
kn7671 is offline
Old 08-20-2021, 12:35 PM
  #53
mrreet2001's Avatar
There are a ton of things it can be. Unless you work for or directly with XRAY you don't know for sure either.
Things we know for sure:
  • It will be called the X4
  • It will be made by XRAY.
Maybe's:
  • There might be a confirmation by one of the team drivers that it will have 4 wheels.
  • There might be a confirmation that the T4'22's SKUs exist already
Rumors:
  • Xray is working on a new Touring Car: This is a pretty much given, but will they change the name? Will they have two Touring Cars at the same time again?
  • Xray is working on a larger electric on road car 8th Scale something? PRO10?
Things to Consider:
  • Xray does not have a NoPrep Drag car which is a HUGE sector right now.
  • Xray does not have a Crawler which is a HUGE sector right now
  • Xray does not have a 24th scale micro car which is a pretty big sector right now
Old 08-20-2021, 01:16 PM
  #54
Maybe's:
Rumors:
Things to Consider:
It might be a quadcopter. Quads are "X" shaped and have four motors. The wheels could be landing gear!
performula likes this.
Old 08-20-2021, 01:17 PM
  #55
I can't even... where's my beer?
DavidNERODease is offline
Old 08-20-2021, 01:21 PM
  #56
Im here for the entertainment. Yall are a trip.
Lonestar likes this.
performula is offline
Old 08-20-2021, 02:05 PM
  #57
Airwave's Avatar
My FWD is an pan-car in fact (MST TCR)
DavidNERODease likes this.
Airwave is offline
Old 08-20-2021, 07:45 PM
  #58
It is a shaft driven touring car
b.wihardja is offline
Old 08-20-2021, 07:49 PM
  #59
sugs's Avatar
Aaaaaand the train is off the rails..... ;-)
sugs is offline
Old 08-20-2021, 11:05 PM
  #60
Dan
Dan's Avatar
Trader Rating: 76 (100%+)
As long as they promote it with this style video, I will buy it.
Dan is offline
