Like Tree2231Likes
Xray X4
    Hide Wikipost
Old 09-12-2023, 09:53 AM   -   Wikipost
R/C Tech ForumsThread Wiki: Xray X4
Last edit by: R Dodge
XRAY X4'22 Helpful tips & setups
Tips:
Installing the hex on the driveshaft - Make 100% sure you have the flat spot lined up on the axle with the cutout in the hex as shown in the manual. If you do not do this, it will make disassembly so much harder. The flat spot is there so you can fit a flathead screwdriver in between the shaft and the c-clip to pop it off when you want to remove the hex. Also, when removing the c-clip I would recommend pointing it down into your pit mat/towel so the clip does not go flying and disappear.
Assembling the upper arms - Make sure to grease the threads on the camber screw (302640). This will make assembly and camber adjustments much easier. Also, when adjusting camber you want to make sure you hold the upper arm so it does not twist while you turn the screw.
Droop - It is important to remove the shocks. All team setup sheets will show droop settings with shocks removed. Simply detaching them from the arm will do. This is a change from how we set droop in the past.
Setups:
**If the super mods on this forum were actually right, and handled things correctly, they would not have gone back and deleted all the posts to hide things
***And since they are in the deleting mood now, they might as well go ahead and just delete all the images of the setup sheet, as originally requested via private comms.
Print Wikipost
Old 09-09-2023, 02:01 PM
  #1846
bigl's Avatar
Trader Rating: 51 (100%+)
I canít find it can you please post a link
bigl is offline
Old 09-09-2023, 02:23 PM
  #1847
It was a setup sheet. Clearly labeled as X4 Ď24 both in file name and at top of the sheet as it would normally be.
however, the link is no longer there. Time will tell how accurate it was.
blueflagger is offline
Old 09-09-2023, 03:23 PM
  #1848
Trader Rating: 23 (100%+)
Probably rge '24 x4f.
hunterdawg is offline
Old 09-09-2023, 06:18 PM
  #1849
R/C Tech Elite Member
Marcos.J's Avatar
Trader Rating: 239 (100%+)
DavidNERODease likes this.
Marcos.J is offline
Old 09-09-2023, 06:29 PM
  #1850
Originally Posted by Marcos.J
Yep. That's what was there.
Old 09-09-2023, 07:13 PM
  #1851
Looks like a Mugen clone. The steering arms are going to be destroying shocks when you hit the boards.
h2e likes this.
LowDrag is offline
Old 09-10-2023, 01:53 AM
  #1852
gigaplex's Avatar
The existing X4 cars could be called a Mugen clone. The new shock placement is a big differentiator.
gigaplex is online now
Old 09-10-2023, 07:36 AM
  #1853
Originally Posted by gigaplex
I don't think the 22 or 23 cars had steering limiters on the A arms either.
'22 has one. It's a shim in the centre of the steering rack.
Sabin is offline
Old 09-10-2023, 07:53 AM
  #1854
I've been running xray for a couple years now and am switching to Mugen. Especially now after seeing the 24'. Awesomatix and Mugen seem to be a few years ahead of xray in technology and development. Not to mention the excessive price Xray charges for spare parts, the kits are overpriced for what you get compared to other brands, and it's almost become price gouging levels. Time will tell, but the new shock location doesn't look like a good place for the average club racer on a budget.
mikedoo3 and h2e like this.
LowDrag is offline
Old 09-10-2023, 03:07 PM
  #1855
gigaplex's Avatar
My point was that it wasn't on the arms
Old 09-10-2023, 03:59 PM
  #1856
Marcos.J's Avatar
yeap its on facebook and instagram
Marcos.J is offline
Old 09-11-2023, 01:05 PM
  #1857
Team EAM
Trader Rating: 79 (100%+)
Originally Posted by syndr0me
Do you think I could get an X4'24 sooner than an A800R?
How many would you like? If you order today you may have an 800R in a few weeks! Supply is flowing again.
EA
Marcos.J and syndr0me like this.
EAMotorsports is offline
Old 09-11-2023, 01:53 PM
  #1858
Marcos.J's Avatar
Originally Posted by h2e
Seems the X4'24 is only getting more complex and expensive. From petitrc.com's spec sheet page, I see the X4/24 is featuring squeezed-in dampers... I like that they tried (just like I did on the h2e four), but the steering arm design has become weird, and there's no steering limiter at the A-arms protecting the CVDs in a crash. Somebody please bulk-buys driveshafts
The bulkheads still look like they could need some strengthening, as I see some stress concentrations that will cause bending.
Front damper position behind driveshaft. See control arm with "expensive" 3d shape.
The lower A arms look more complex and besides compound there's 4 individual designs.
Lower arms have damper pickup moved down. Nice expensive A arms!!
Active rear shocktowers are also adding cost,
Active shock holders like MTC2
Rear bodyposts are attached to bulkhead again. The rear chassis overhang is still improvable in my eyes.
Interesting to see 1.5mm Alu chassis option... if that ever is going to be flat/straight?
interesting going like the MTC2 but with the shocks in a different location its weird set up sheet got released before the 14 part mini video series
h2e likes this.
Marcos.J is offline
Old 09-11-2023, 03:28 PM
  #1859
PDR
PDR's Avatar
Trader Rating: 31 (100%+)
Maybe WGA members do the script.
Marcos.J and gigaplex like this.
PDR is offline
Old 09-11-2023, 03:41 PM
  #1860
Marcos.J's Avatar
makes sense with them on strike the release will be delayed
Marcos.J is offline
