Old 04-02-2006, 05:07 AM   #1
F1 Nutter's Avatar
Default servo voltage problems
I am having a huge problem that I need all the help I can get with. I run a Yoki BD with Nosram Dominator evo ESC, Spektrum, and a Hi-Tech HSC-5996TG servo with a Peak hellfire motor. Basically what happens is the servo freezes all the time under rapid usage especially when on power. I have been told that it could be the reciever not being able to handle enough voltage and going into a sort of shut down mode, so when I get on the power the motor takes all the voltage away and the servo just freezes where it was. has anyone else had this type of problem and if so how can I fix it?
F1 Nutter is offline   Reply With Quote
Old 04-02-2006, 05:32 AM   #2
More than likely it is a combination of the digital servo not being set up correctly which can cause MASSIVE stall current and a rather weedt BEC circuit in the Nosram, not being able to provide enough power to the servo under high loading.
DA_cookie_monst is offline   Reply With Quote
Old 04-03-2006, 09:54 AM   #3
Had the same problem with de LRP Q2.
BEC circuit is not strong enough.
I had problems with my personal transponder. sometimes there was not enough power for it and I missed laps.
there are a lot more threads about this problem with the LRP/Nosram
Jan van Steeg is offline   Reply With Quote
Old 04-03-2006, 10:12 AM   #4
koabich's Avatar
Send a message via Yahoo to koabich
I had the same problems. I installed the LARGE capaciter from the LRP Worlds Kit and the problem was solved. No more problems!!
koabich is offline   Reply With Quote
Old 04-03-2006, 11:24 AM   #5
Send a message via AIM to RcCzarOfOld Send a message via MSN to RcCzarOfOld Send a message via Yahoo to RcCzarOfOld
Get the pre-wired capacitor from Spektrum and install that. That should help when the motor is pulling a great deal of amperage. Is this one of the first versions of the spektrum released? That could also be part of the issue. Most likely though, the spektrum cap will solve the problem and it's a cheap fix too. (4-6 bucks)
RcCzarOfOld is offline   Reply With Quote
Old 04-03-2006, 11:42 AM   #6
Nevergreen's Avatar
I remember i had the same problem (same servo,QC2 and BD), by using the capricator from LRP or Novak all the probs are gone.
Nevergreen is offline   Reply With Quote
Old 04-04-2006, 04:43 AM   #7
F1 Nutter's Avatar
Thanks for all your help guys. One of the racers from our club was kind enough to let me use his pre-wired Spektrum capacitor but it didn't solve the problem. I think I'll try the large nosram capacitor (I think it comes in the nosram ultimate accessory kit) and if that still doesn't work then I might try to solder the positive lead from the servo directly to the positive battery terminal on the speed controller.
Old 04-04-2006, 12:52 PM   #8
Jimmy Morris's Avatar
Yeah, I have the same problem. Sure does suck. I will be getting a mms soon though. I put a cap from my gt-7 on my qc2 and it made it glitch.
www.superiorhobbies.com
Jimmy Morris is offline   Reply With Quote
NiCD/NiMH Voltage vs Lipo Voltage bryanleec Radio and Electronics 10 02-06-2008 06:08 PM
GP3300 voltage problems wog....supraman Radio and Electronics 5 11-29-2007 11:32 PM
Orion 4800 Lipo problems.. voltage fluctuating... Justinian Electric Off-Road 2 01-08-2007 12:58 PM
Servo Voltage Question StephenSobottka Electric On-Road 5 09-02-2005 09:48 PM
Servo Voltage Qn (Ko Propo 2123) jwwu Electric On-Road 8 05-10-2002 07:54 AM
