Need tips on choosing and breaking in new motors!!!
Guys, I'm fairly new to the rc-cars. ... . I have just bought TA-05 chassis and I’m looking for a motor for it that is legal for TCS GT-2.
Can anybody help me find the best one?
Also can anybody give me some tips on how to break-in GT-2 legal motor?
Thanks in advance for your help!
Well I can give you some help on your motor tuning...
All you have to do is go to this site and it will tell you all the answers...
www.motortuningsercets.com
If you tell me what TCS GT-2 allows for motors i might be able to help you that one to...
Super Moderator
The GT2 class in US TCS races uses ROAR-legal stock motors, so ones like Trinity's Monster or Co27 would likely be the best bets, depending on the track you'll race on. How big is the track you plan to run on? And is it very technical, or more wide open & sweeping in the corners? Those things will help determine which motor would be easiest to dial in for it(though I have to say after playing with a Co27 for a few weeks now, I have t say I'm impressed, seems incredibly versatile, could be good anywhere).....
Grizzbob,
It seems that the clousest to me is the one inside the Hobby Town USA store in Frederick MD (22miles from me) Idon't kmow if you been to that one. It has one long strach along the back wall, one wide turn along the right wall, and all other sorts of turns and short straight peases. On that TCS race one guy (Pall)told me that that track is considered just bearly as long one.
Here I found some photos about that track and the tcs race www.rcclubmd.com
What would you guys say about P2K2 motor?
Mans343, the allowed motors are the "ROAR-legal stock motors".
By the way it seems to me that the website that you mention in your reply doesn’t work, may be it is just temporary.
Super Moderator
Originally Posted by Viat
Grizzbob,
viat - If you have the opportunity to look through all the motors before you buy (some shop owners will allow this), you need to look at the dyno read out to help choose a good motor. The most importent number you should look at is the power (watts) followed by efficency. You want to find a motor that has both high watts and efficency. The reason for this is that a motor that has these two numbers being high, will be one that has a well built endbell and ameture.
After that is rpm and torque, you can decide for yourself which of these attributes is going to be beneficial to you and the racing you will be doing, however you need to remember that these numbers usally go hand in hand, if one is high the other will be a bit low. This is because power(ie watts) = torque x rpm.
Alot of noob racers make the mistake of choosing a motor that has the highest rpm, what high rpm generally means is that the brush hoods are not aligned properly and the motor will not proform on the track. Although if for example you manage to find a motor with very high rpm, but it still has high watts and efficency this would be the motor to choose.
After taking all this into consideration you will still not be garenteed of a great motor, although it should help to weed out most of the lemons.
Super Moderator
Grizzbob,
Thank you for the advice!
What are you running (Chasses and motor)? and what do you think about the TA-05 kit?
I have bought and built my first TA-05 Kit with Ferrari body.
I started building on Thursday late evening and didn't want to stop assembling it until it was done. The chassis is an artwork of RC-car design!
Now I'm waiting on delivery of motor and radio and can't wait to race it!
I just recived Trinity rc2140 "Revange of the Monster" a "Monster Horspower Stock" 27T-24 degree High RPMs Motor and as I said befor I have a brand new TA-05 Chassies which came with silver can 540 motor and 22T pinion gear.
What do you guys think about using this Monster Horspower Stock motor with that pinion gear???
With a freshly cut comm, and new brushes you should break in your motor for 300 sec. If you are using a battery charger with a motor break-in option you will see the amp draw go up as the brushes conform to the comm shape. After this finishes recut the comm, and your motor should be good to go. I would try trinity 767's for those motors, and maybe a green/green spring combo. Hope that might help you a little.
Super Moderator
