twister/mms3
twister/mms3
What r the diff's from these to speed controls? I know that they are both made from ko but it says here in the corally book that on there mms3 ko makes it but with diffrent specs just for corally? is this so with the twister is it not the same as the ko vfs? Im going to order one of the above so help me out thanks..
There are many OEM KO speedos...all the ones with graphite-patterned cases are the newest versions currently available (i.e. twister 2.1, VFS-1 competition)...not sure about the Corally.
r they better then the GTX novak? should i maby trade my GTX off for one of these or stick with my current setup? Im also thinkin of buyin a twister guy has one for sale thought i might give it a shot got me a new rdx and just want to put the best on it...
Does any one know the part number for the lead to connect the speedo to my laptop to change the profile.
is there any of these ko speedos that are programmed from the factory for stock27 motors?
im sure there is one that is program for a stock motor you just got to figure out if its kopropo,twister,mms3.
