XPRESS Execute XQ2S >
XPRESS Execute XQ2S
Like Tree194Likes
XPRESS Execute XQ2S
Old 03-17-2022, 09:42 AM
  #376
Trader Rating: 24 (100%+)
Anyone have an issue with a steering knuckle not moving freely?
phatboislim is offline
Old 03-17-2022, 12:27 PM
  #377
Trader Rating: 20 (100%+)
First thing, are you running the v2 c hubs?
Second, if you are, you might try lightly sanding the bottom of the steering knuckles to give them a little more room in the c hub.
phatboislim likes this.
timberline97 is offline
Old 03-17-2022, 05:33 PM
  #378
Yup, I did. Had to sand down both my knuckles to get them to move freely
ntc3freak is online now
Old 03-24-2022, 02:40 PM
  #379
Default Chassis Flex
I am just experimenting with front and rear chassis flex and wondering if any of you are playing around with this.
I note in the manual that there’s a med and low flex option for the front but I assume you can remove the chassis stiffener completely to give a high flex at the front?
Now that the asphalt track is warming up a bit outdoors I am going to add flex at the front and stiffen up the rear to try and get better on power initial turn in…
why is everyone else doing?
mr.si is offline
Old 03-24-2022, 06:56 PM
  #380
moparSRT's Avatar
also check the ballend, the black ones tend to bind up the suspension a little, the grey ones are a great upgrade.
moparSRT is offline
Old 03-24-2022, 07:58 PM
  #381
I've found the grey ones to be quite an upgrade in terms of smoothness, but they seem to be quite brittle. I ordered a bunch to replace the kit ball cups, but one of them cracked after popping onto the ball stud. They also seem to need holding on to while adjusting the turnbuckles. My steering ones always seem to pop out of the balls when adjusting toe.
If I were to do it again I would have probably gotten Xray ball cups (and maybe even the ball studs). Other than the one cracked ball cup and some of them needing to be held to adjust turnbuckles, they're definitely an improvement over the stock ones.
Old 03-28-2022, 03:03 PM
  #382
IslandBwoy's Avatar
The xray ball cups do not work on the xpress platform. I learned this the hard way just a few weeks ago when I had to borrow a ball cup from an xray driver AND a ball joint to go with it. Xpress balls are bigger (no pun intended).
IslandBwoy is offline
Old 03-31-2022, 10:10 AM
  #383
Default Xpress battery mount
I broke one of the arms off my battery mount last Sunday. Would the X-ray battery arms (graphite) fit or have near the same bolt holes? I could get it complete or just the arms.
Xrayray is offline
Old 04-16-2022, 10:00 PM
  #384
Default XQ2S Leaking Differential Fluid
Hi All,
Thank you for the assistance!
I finished the XQ2S build, and all seemed fine, except the differential is leaking and spraying drops of differential fluid. I assume either one of the O-Rings is crimped or the gasket is torn.
The gasket material is very brittle and was already wrinkled when I installed it. Before I disassemble the differential would like to order parts; I assume I should get;
  1. Hiro Seiko Pure Silicone Diff Oil 60ml 5000cst $8.95 AUD
  2. Xpress XP-10184 XQ1 Silicone Gear Differential O-RING 5x2mm 10pcs $7.95 AUD
  3. Xpress XP-10183 XQ1 Silicone Gear Differential O-RING 25x1mm 10pcs $7.95 AUD
  4. Xpress XP-10179 Gear Differential Gasket 5pcs $7.95 AUD
I would appreciate any advice or suggestions; thank you! Cheers.
museguy is offline
Old 04-16-2022, 10:49 PM
  #385
I would check these out first.
Seals
and yes they do fit.
museguy likes this.
Old 04-17-2022, 03:10 AM
  #386
gigaplex's Avatar
Where is it leaking from? If it's coming out of the outdrives, check the o-rings. If it's the pulley seam, replace the gasket and make sure it's closed properly.
museguy likes this.
gigaplex is offline
Old 04-17-2022, 10:18 AM
  #387
Thank you gigaplex
It looks like it is coming from the pulley seam, I will order the new gasket and replace it. Cheers
museguy is offline
Old 04-17-2022, 10:23 AM
  #388
Seals
Thank you timberline97
I will added the X-Rings to the order. Cheers
museguy is offline
Old 04-18-2022, 04:47 PM
  #389
Hi everyone, I have just assembled the kit but I have a problem when I accelerate and while I turn the steering wheel vibrates the belt and the whole car. it's normal ?
ENiGMiST4 is offline
Old 04-18-2022, 05:11 PM
  #390
gigaplex's Avatar
At full steering lock, the stock driveshafts will cause some vibration. That might be what you're experiencing. The fix is to upgrade to the DCJ front axles.
trx-1racer and timberline97 like this.
gigaplex is offline
