Xpress Execute XQ10F
#16
Originally Posted by gigaplex
No. There's two ways to get an XQ10F. One is to buy the XQ10F kit, you only get the FWD parts. The other is to buy the XQ10 kit and then get the XQ10F conversion. Costs more but you get the parts for both.
#17
The standard ones are too short i guess?
I just got the car (XQ2S + fwd kit) and i have a million questions :-)
#21
XP-10863
#24
i'm using 2 spare front posts mounted horizontally in the back
#26
I've asked around and the chassis ride height should be approx 4.8
I can't manage to go lower than 6.
If i keep turning the shock ring the spring is too short and moves.
What am i doing wrong??
#28
Keep going until you get the desired ride height. After you've done that, adjust the droop screws (big chunky set screws in the arms that limit suspension travel) to reduce the amount that the arms drop. With the correct amount of droop and ride height, the springs should be the right length.
#29
Thank you!
#30
Is xpress going to release an aluminum chassis for the xq10f that anyone knows of?
