Old 12-15-2002, 07:11 AM   #1
Carbon_Fibre3's Avatar
Default LRP Pulsar Charger
Hello people, this is my first post.. yay.
Anyways, i am wondering anyones oppinion on the LRP Competition PUlsar Charger, what are you experiences? waht have you heard? etc.
Carbon_Fibre3 is offline   Reply With Quote
Old 12-15-2002, 07:27 AM   #2
Send a message via Yahoo to miniman
Thumbs up
It works very well for me. The only things are that it is getting a bit hot when "mathcing" (charging/discharging) packs, and that you can`t discharge with a higher Amp-rate, and to a lower V-setting(when discharging packs with few cells).
miniman is offline   Reply With Quote
Old 12-15-2002, 07:27 AM   #3
sorry guys.. searched and found heaps on it..
sorrys
Old 12-15-2002, 07:31 AM   #4
Spillertwo's Avatar
Hello,
I have the LRP pulsar now about a month and it is a good charger.
What do I like about it:
+ it doesn't false peak
+ it can run my com lathe and my soldering iron
+ it can run in my motor
+ it can match my packs, ie charge - discharge, and then give
you discharged capacity and avarage voltage and time
+ it charges up to 8A
+ you can set a charge delay
+ I like it's blue color
What don't I like:
+ it doesn't have a temp sensor
+ it only discharges with 10A
+ the blue backlight display is unreadible if you don't have
enough light
All in all I bought it especially for the run in possibility to power my
com lathe, soldering iron and to run my motor (in races I always let my motor run just before the start).
I think it is a good charger to but I also have a Robitronic 2000+ charger and this one is still my favourite charger (temp sensor, clear menus,...).
Spillertwo is offline   Reply With Quote
Old 12-15-2002, 09:22 PM   #5
I have had a pulsar for about a month. I like it very much, however while breaking in a motor today I noticed the voltage varied. The motor speed went up and down. I measured the voltage at the leads and found 1.2 volts when the display on the charger said 3 volts. Anyone else had this problem?
toomanytoys is offline   Reply With Quote
Old 12-16-2002, 06:09 AM   #6
KINGZJ's Avatar
Send a message via AIM to KINGZJ
That is my big beef with this darn charger. The motor voltage varies no matter what you put into the charger you will be lucky to get at most 3 volts out to the motor. if you turn it on without a motor on it, it will read the correct voltage but when you hook up a motor it will be much lower. I called lrp and talked to them and they said that it is designed to lower the voltage depending on the amp draw. Now I ask what is the good of that it is pretty much useless to break in motors or run a com lathe. In my opinion they false advertised it who wants to run a motor at 1.2 volts it barely turns over.
KINGZJ is offline   Reply With Quote
Old 12-16-2002, 07:16 AM   #7
Cole Trickle's Avatar
Hmmm. Dissapointing. Actually, I was considering this charger, but this dont sound nice.
The manual promises a lot, but if that motor-run-in-thing dont work properly....
From the manual:
MOTOR RUN-IN
You can use this function in a number of ways, e.g.:
Running in the motor or motor brushes (check for excess current consumption).
Powering com-lathes
Powering 7.2 V soldering irons
The voltage setting (you can change this during operation), current and operating time are displayed.
SET Motor Run-In Voltage:
The voltage is continuously variable from 2.0 V to 7.2 V. We recommend a voltage of 4.0 V for running in
motor brushes. The special run-up electronics allow trouble-free running-in of motors with very high no-load currents and low number of turns when you set the charger to low voltages.
Schumacher Mi5 - Sanwa MT-4 / RX-462 / KO Propo PDS-2123 - Nosram 5600 X-treme Saddle Pack - LRP SPX Zero/X12 17,5 - Nosram Stealth Touch Evolution - MAAS SPS 9250
Cole Trickle is offline   Reply With Quote
Old 12-16-2002, 09:39 AM   #8
KINGZJ's Avatar
Basically it cannot handle any load at all. Even a crappy stock motor will pull about 5-6 amps at 2-3 volts on a turbo 35 and on a lrp it limits the voltage going to that same motor to only about 1-1.5 volts and at that voltage it is useless for anything it would take you a year to break in a motor.
Old 12-16-2002, 09:48 AM   #9
burito's Avatar
You're right to a point that the run-in feature wasn't perfect, the voltage was limited to make sure all motors can be run in some way. So it was even possible to run a 8t with high timing, this would draw way more then 9A! The downside was that the voltage on the display was wrong under some circumstances and that the motor ran rather slow sometimes!
But this really doesn't mean that the brushes can't be broken in or that the comm-lathe will not run fine, that will work without a problem at all.
Anyway, we recently did an update and the newer models have spot-on voltage and allow currents up to 14Amps!
Guess that all the positive features shouldn't be forgotten! It was certainly never the case that we tried to mislead anyone.
Hope that helps and answers the questions.
Reto Koenig
burito is offline   Reply With Quote
Old 12-16-2002, 09:50 AM   #10
BigDogRacing's Avatar
R/C Tech Charter Subscriber
Send a message via MSN to BigDogRacing
Iceman (racing partner) just got one, and the dang blue backlight went out before he ever got to charge a battery!! He called LRP and they said it must be the fuse, but he replaced the fuse- still no light. He's pretty disappointed and so am I.
Kingzj- sounds to me like a lame excuse for a problem they didn't catch before going into full production- what about you?
BigDogRacing is offline   Reply With Quote
Old 12-16-2002, 12:27 PM   #11
KINGZJ's Avatar
Ya it was pretty lame I am still waiting for mine to get back from lrp I sent it in because I thought their was a problem
Old 12-16-2002, 06:38 PM   #12
Burito, you said there is an update that will allow more amps, will LRP update the early Pulsars for us or are we out of luck? Also, even when using 2-3 volts for a motor or a lathe the voltage varies causing uneven RPM will the update fix this? I really like the charger, the timed start for charging is an excellent feature as is being able to change amps during charge. I would hate to get rid of it, I just don't like the output issue.
Old 12-16-2002, 07:41 PM   #13
KINGZJ's Avatar
As a charger is is fine everything else sucks
Old 12-16-2002, 09:36 PM   #14
STLNLST's Avatar
Trader Rating: 21 (100%+)
What will be done to all existing chargers? I just bought mine about a week ago. Am I SOL??? I guess I'll have to give AE a call and see what can be done.
REMEMBER THE GOOD OLE DAYS..........THEY'RE NEVER COMING BACK SO WE'RE STUCK WITH THE MESS IN FRONT OF US!!!!
STLNLST is offline   Reply With Quote
Old 12-19-2002, 02:04 AM   #15
Send a message via ICQ to MattW
Reto, Are the new ones in full circulation yet?? I am thinking about getting one in the next couple of weeks, so would obviousely rather an updated version.
cheers
MattW is offline   Reply With Quote
Turbo 35 GFX Charger & Pulsar 2 Competition Charger ZeroCool101 R/C Items: For Sale/Trade 6 02-20-2008 07:57 AM
WTB Lrp pulsar charger SaTsOk R/C Items: Wanted to Buy 1 04-06-2007 03:10 AM
PULSAR 1 charger cheehtae R/C Items: For Sale/Trade 3 03-21-2007 03:17 PM
WTB: LRP PULSAR/2 CHARGER! R-job R/C Items: Wanted to Buy 1 04-12-2006 04:46 PM
LRP Pulsar Charger letitroll R/C Items: For Sale/Trade 5 03-07-2005 09:54 PM
