SERPENT 750E
#16
So does it run 10th esc and motor or 1/8th motor and esc.
Would say running a hobbywing xr10 pro with g3 motor work or is that not powerful enough for the class? Seem a confusing car. Understand for the drag racers a good chassis but for circuit racers where does it fit in. If it recommends 1/8th esc and motor then why not just run 1/8th e onroad in either lmp or gt format.
#17
#18
#19
Somebody please explain the motor mounts and the so called "power box" to me. The standard version for 10th scale motors is fastened to the chassis at two points, while the one for the bigger 8th scale motors is not attached at the front. Those big motors have more torque, so they should need a more rigid "power box", how is it sufficient with one of its legs missing? And if it is rigid enough without the front chassis mount then why is it there for the small motors?
#20
https://www.serpent.com/xcart/serpen...anual_750E.pdf
#23
Today is a sad day... All my hopes for this car have been destroyed lol
Honestly nowhere, the previous model was a little bit heavy but it was nice when it comes to mass repartition and transmission. This model is a huge regression. The LiPO location would really be a disadvantage, especially if you planned to race it on track.
We are far far away from the work done on the 988e...
#24
#25
The interesting thing is my 1/10 electric now drives as well if not better than my 1/8e and is more agile thanks to its size (its converted to 220mm spec).
