LRP SPHERE COMP. ESC (80700) >
Old 01-09-2007, 02:53 PM
  #106
dr_hfuhuhurr's Avatar
Trader Rating: 95 (100%+)
Are you using the old spektrum system? If so, you might be sending the receiver into failsafe mode.
dr_hfuhuhurr is offline
Old 01-09-2007, 03:05 PM
  #107
Originally Posted by Wild Cherry
Question
Are you setting your Sphere on the sportsman mode ?
I'll check that.
Thanks!
Crashby is offline
Old 01-09-2007, 03:07 PM
  #108
It could be. I would think that if the receiver (spectrum 3500) went into the fail safe mode, I would also loose the steering. I have steering, just no throttle.
Crashby is offline
Old 01-09-2007, 05:50 PM
  #109
AdrianM's Avatar
The speed controls cannot tell a diffrence between a Novak, LRP, GM or Orion Motor. Everything works with everything. This is what the current BL standards (connector pin outs, phase color and letter codes,etc...) were set.
There has to be some other cause for your problem. If you were running the old Spektrum that might have been the problem. I have seen what you describe with the original Spektrum systems and mod brushed motors.
AdrianM is offline
Old 01-09-2007, 06:00 PM
  #110
i'm thinking the reduced voltage to the rcvr is the problem.
Turtlemaster is offline
Old 01-09-2007, 06:55 PM
  #111
Because the steering wasn't lost I don't think it's the spektrum failsafe. Maybe a loose wire somewhere? Would one of the sensor wires loose cause something like this?
Old 01-09-2007, 11:42 PM
  #112
Tech Legend
Wild Cherry's Avatar
sensor wire , make sure the plug`s are not loose...
If he is using the "sportsman" mode this happen`s with my experience....
The Esc say`s, you want to much power , and won`t give it until you back off the power..
Sometimes it will not even launch off the line , done that a lot of times for me..
This is only if you are using the sportsman mode ...
Wild Cherry is offline
Old 01-10-2007, 02:48 AM
  #113
The 2007 edition already on sale.any different from old model??
http://www.racing11.net/shop/product...roducts_id=988
initialrays is offline
Old 01-10-2007, 12:41 PM
  #114
This is exactly what they are doing. If I back off the throttle a little, the throttle comes back on instantly. If I don't, the throttle continues to stay in the off mode. I will check my mode settings again.
Crashby is offline
Old 01-11-2007, 08:09 PM
  #115
Originally Posted by burito
Sorry, didn't mean to come across the way I obviously did to you. It didn't really look as you were looking for my help, I understood it that you just wanted to state your bad experience.
Drop me a PM (or better email) with the full details of that unsuccesfull repair and I'll see if there's anything I can do for you from here.
Burrito, open up your PM or post your email address and I will
Cam
Cammer is offline
Old 01-11-2007, 11:27 PM
  #116
Shop Owner
nnick's Avatar
Yes they are different, has newer software and more profiles
Nick
nnick is offline
Old 01-12-2007, 05:25 AM
  #117
Hi
Anybody knows the specs for the new LRP touring spec? I want to know how much current it can handle continuously...
Thanks in advance
Itchy is offline
Old 01-14-2007, 08:58 PM
  #118
Ok...I need to get a speedo this week (racing brushless Sunday). Can anyone tell me when the Sphere Comp will be available in the US? Tower says Mid-Jan, Horizon Says Early-Feb. GTB 4 cell is pretty much the same on both.
Can anyone tell me if it will be available anytime soon? Please?
Old 01-15-2007, 11:40 PM
  #119
Hiya
I have a GTB brushless speedo, and am looking at running an LRP X11 5.5 brushless motor on it. Is there anything i should be aware of?, and what FDR should i go with in a TC ?
MoonTrap is offline
Old 01-17-2007, 03:12 PM
  #120
AdrianM's Avatar
Any Euro racers out there know where to start gearing an LRP Sintered 5 Star on 5 cells? This will be on a fairly tight 45m x 20m track.
AdrianM is offline
