Old 08-09-2007, 01:33 AM   #601
Toughbeard's Avatar
Hello Guys,
I have finally got myself a Brushless system and did get to test it yesterday. I have the TC Spec with a Novak 4.5R coupled to it. I was running 9.75FDR with 62mil tires. The motor was barely hot and no thermal shutdowns or blow ups
Couple questions..
1. That fan on the ESC sounds more like a Jet engine than a fan... Any solutions? or is mine faulty?
2. After I turn the car on sometimes the car surges. it moves forward with a jerk.
3. I solder my battery and when I solder the second wire I hear a pop... is that normal?
Thanks in advance...
Toughbeard is offline   Reply With Quote
Old 08-09-2007, 01:41 AM   #602
BlackedOutREVO's Avatar
Trader Rating: 67 (100%+)
Originally Posted by Toughbeard View Post
Hello Guys,
Couple questions..
Yeah, the LRP fan is fast and loud! Thats normal
Dont know on 2
And yes, thats normal
BlackedOutREVO is offline   Reply With Quote
Old 08-09-2007, 03:49 AM   #603
The pop you hear is the capacitor charging, if you pay very close attention you can see this too. Completely normal.
With the battery unconnected put together + and - wires to fully discharge the capacitor, put one wire on the battery and look while you put on the second wire, you will see a spark as the capacitor is drawing a very high current from the battery to charge itself.
Make it idiot-proof, and someone will make a better idiot.
Quante is offline   Reply With Quote
Old 08-09-2007, 08:43 AM   #604
Tech Legend
Wild Cherry's Avatar
Originally Posted by AARON YOUNG View Post
I have used lrp for about ten years and had no problems till lately.The motor is some new parts. The end bell is new cause the threads still have all the annodizing.its just the can and the plug that look used.I will buy a tekin next time over lrp.
A scratched motor is a problem ?
If your Tekin comes with scratch on it, what will U say to them ?
waaaaaa !
I`ll bet that`s what you`ll say....
Any driver can copy a great set up, a Champion however will steal it .
If Jesus returned as a Rc car he be a Rc10 B5M
George W. Cherry
Wild Cherry is offline   Reply With Quote
Old 08-10-2007, 04:13 PM   #605
I dont know if I should post this here... But
I will want to cut my sensor wire, How should I do this? I know for my servo, Transponder, And speedo I cut the wires to where I want them, and then I bought the lil plugs that go onto the rx's pins, and crimp them and its like I never messed with them..
But I think the sensor wire plugs are smaller, And I dont want to cut the wires and sloder them back togather at the right length..
Any opinions?
Old 08-10-2007, 05:28 PM   #606
Nexus Racing's Avatar
Any opinions?
My suggestion is to either:
1) purchase the sensor wire that is the correct length for your application (they are available from 100mm to 270mm from LRP, Orion, Novak, etc), or
2) just fold the sensor wires and put heatshrink over them (this is what I do to my Novak motors).
I have seen someone accidentally tear their sensor wires on the track...it did NOT look like they were having fun trying to solder those awkward wires back together !
NEXUSRACING.com
Nexus Racing is offline   Reply With Quote
Old 08-10-2007, 05:42 PM   #607
100mm is HUGE
Got any pics of the folded? Can you tell that there all folded up in the shrink?
I wouldnt mind soldering them, but once you put the sleve back on, you would notice all the lil things of shrink sticking up.... Thats why I would want to buy the pins in the plug and wire those up, I just dont know why makes them
Old 08-25-2007, 02:30 PM   #608
spoket's Avatar
Default Sphere 2007 and X11 4.0T
Im recently buying lrp sphere esc 2007spec (due to LRP TC Spec out of order) and X11 4.0T motor. Wanna confirm that can i use the motor without any problem. Btw i also buy the brushless world option kit.
spoket is offline   Reply With Quote
Old 08-25-2007, 02:49 PM   #609
Since the thread is back up
I took the fan off my Sphere TC because when I got home and cleaned it, the wire's broke off at the solder tab in the fan, and I have NO clue how to take apart fans with out messing something up lol
In stock do you guys think It will run fine? Or will it thermal?
Old 08-28-2007, 10:19 AM   #610
Hi all,
i have the X11 4.5 motor. The thread of the 3 small
(1,5mm) front screws is damaged. I was carefull not to overtighten the
screws, but i did open the motor regulary to reoil the bearings.
Did any had the same problem? If so, any advice on how to fix this?
Thanks in advance
Itchy is offline   Reply With Quote
Old 08-28-2007, 01:25 PM   #611
V12
V12's Avatar
The LRP catalogue says over 3.5T for the competition 2007 spec so it should work. I think you donīt need the worlds option kit as a bigger cap is used with the 2007 spec already and the heatsink is supplied also. Actually you just need the fan from the kit but this will improve cooling for sure.
V12 is offline   Reply With Quote
Old 08-28-2007, 01:32 PM   #612
V12
V12's Avatar
Usually you canīt take apart any of the fans but sometimes there is just a sticker over the soldertabs on the fan. You have to remove the fan from the ESC and look as the soldertabs are on the other side of the fans. If not you just could buy a new fan but make sure itīs a 5V type.
Hmm, stock? Do you mean youīre just running stock motors with the TC spec? If so this really will work without fan, but then make sure isolating the fanwires coming out of the ESC.
Old 08-28-2007, 04:11 PM   #613
Its all off, I had it off to clean all the heatsink ribbs and the wires broke off right after where the wire gets soldered on to the tab in the fan, So because I was inside of the case anyways, I also took off the wires that hok onto the speedo and sharpie'd them red and black
Yeah, im running a novak 13.5, what do you mean isolating the fan wires? There is no fan wire anymore, or is there more to that? Its works fine lol
Old 08-28-2007, 05:02 PM   #614
He's just saying that if you have wires sticking out, they should be insulated so they don't short.
NEXUSRACING.com
Old 08-28-2007, 06:29 PM   #615
Ohh ok, thats what I thought
LRP Sphere Comp theprocess Radio and Electronics 13 07-23-2008 11:29 AM
WTB Lrp Sphere Comp Terry M R/C Items: Wanted to Buy 2 04-15-2008 05:11 AM
WTB 2 Sphere 80700 racer34v R/C Items: Wanted to Buy 0 03-05-2008 03:33 AM
Sphere Comp and Sphere TC Differences Paul_67 Electric On-Road 4 08-20-2007 03:27 PM
LRP SPHERE COMP. ESC (80700) + 13.5 wannabee R/C Items: For Sale/Trade 15 02-10-2007 05:25 PM
