Old 06-17-2007, 08:49 AM   #526
Tech Legend
Wild Cherry's Avatar
Originally Posted by Daddy View Post
Do I need to change the bearings?
I would have thought I would get at least 2-300 runs and by that time isn't the rotor cooked?
Depends how long they will last ,if you are beginning to hear the motor getting loud or making a grinding sound.
Replace the bearing`s....
Any driver can copy a great set up, a Champion however will steal it .
If Jesus returned as a Rc car he be a Rc10 B5M
George W. Cherry
Wild Cherry is offline   Reply With Quote
Old 06-17-2007, 12:59 PM   #527
i have got one of these speedos the 80700, i was just wondering because i have been using 4.5 turns on it, now i am going to 3.5, will the new motor blown it up or heat it up more?
jordan.norwood@ is offline   Reply With Quote
Old 06-17-2007, 01:10 PM   #528
Super Moderator
Marcos.J's Avatar
Trader Rating: 182 (100%+)
if you are going to run the 3.5 i would get the TC spec, i had one go up in flames with the 3.5
Old 06-17-2007, 01:45 PM   #529
yes but the reason it did properly did blow up is because you did not gear it right.
Old 06-19-2007, 03:00 AM   #530
Doughty's Avatar
Hi Guys,
I run a B4 off road and want to get a TC Spec Sphere because it has a higher BEC (5.8v). I want to know will I have profile problems as its designed for touring cars? Also is the TC Spec's heatsink taped on, or a metal/mechanical attachment?
Thanks.
I run sphere TC spec in my 4WD off-road and it feels great, it should be perfectly fine in 2WD.
the heatsink is attached directly to the FETS, not sure how but it is 'fixed' and non-removeable, it does not have the reguar 'plate' that the origional sphere and sphere comp have.
Doughty is offline   Reply With Quote
Old 06-21-2007, 06:15 AM   #531
Daddy's Avatar
Thanks Doughty, that helps me greatly
Daddy is offline   Reply With Quote
Old 06-23-2007, 05:01 PM   #532
MACH55's Avatar
Trader Rating: 22 (100%+)
How do you set the DRAG Brake on the new Sphere TC???
Anyone??
MACH55 is offline   Reply With Quote
Old 06-23-2007, 06:17 PM   #533
AdrianM's Avatar
Anyone??
Its called Automatic Brake. Value 2 is the default and what most racers use with sintered rotor motors. In 1/12th and oval applications you may use 1 or 0. If you need to use more than 2 your car is not setup right
Old 06-23-2007, 06:20 PM   #534
AdrianM's Avatar
If you need to take the fan off to make it fit in an off road car you can. Just clip the fan wires in the middle so you can reconnect them later if you want to.
Off road applications do not pull as much current as on road and you run much milder motors so the speedo will naturally run cooler even without the fan.
Old 06-24-2007, 11:23 AM   #535
TA05ers's Avatar
Hi Burito,
Bought this ESC (80700) about 3 months ago and got it mounted on my TA05. It has been working perfectly.. really impressed with how fast it powered my Tamiya stock RZ motor!!
But, I am afraid that my precious Sphere has seen its days.
Though the LEDs on it still responds to the throttle, but no power is transmitted to the motor. I have tried hooking up to a multimeter. There are current flowed, but this is not the case when I hook up the motor together with the multimeter. It seems when there is load, no current is flowed.
Please help out here if you know what I can do to save it!! Not only coz of $$$, but I really love this baby!
If it helps, this happened with an ambient temperature of 28C. I did not have a single thermal cut experience prior to this sad event. I also have both the heatsink and the fan installed. To make it even odd, it happened in my first run.
TA05ers is offline   Reply With Quote
Old 06-26-2007, 09:46 AM   #536
TA05ers's Avatar
Originally Posted by TA05ers View Post
Hi Burito,
Did I scare anyone away with my plead for help?
Old 06-26-2007, 12:00 PM   #537
Do LRP ceramics fit the Novak BL motors ?
Chris Reilly is offline   Reply With Quote
Old 06-26-2007, 12:03 PM   #538
Send a message via ICQ to Jan Larsen
@ TA05:
Sounds like something is broke internally and could quite possibly need a trip to the factory for fixing.
Jan Larsen is offline   Reply With Quote
Old 07-01-2007, 10:51 AM   #539
fast-ho-cars's Avatar
Default LRP TC SPEC Sphere no drag brakes
a fellow racer just got his yesterday, i set-up his cars due to him being color blind and gets lost in set-ups/mode configs.
i went thru the TC Sphere set-up and the modes, with value 6 on the DB, you let off and the car coasts 10+ with a N-13.5. also when you press forward the car does brake but not as hard as his other sedan with a older LRP Sphere (aslo has a N-13.5). his sedan with the older Sphere, if your going full throt and hit the brake the car locks up fast/instantly. the new TC Spec doesn't even come close in the braking department...handbrake or drag brake effect.
we run on a super-tight carpet tracks, he wants drag brake. i tried 2 thru 6, i can barely tell the difference
fast-ho-cars is offline   Reply With Quote
Old 07-01-2007, 12:05 PM   #540
corallyman's Avatar
Trader Rating: 99 (100%+)
Fast-Ho,
I don't have a TC spec speed control but I read the instructions for one yesterday. It sounds like to me his transmitter settings could be off, like his atv's or endpoints. I say this because as a TC spec speed control even more than the other speed controls should have even more braking ability to control a heavier and potentially faster vehicle. I would check there first.
Steve
corallyman is offline   Reply With Quote
LRP Sphere Comp theprocess Radio and Electronics 13 07-23-2008 11:29 AM
WTB Lrp Sphere Comp Terry M R/C Items: Wanted to Buy 2 04-15-2008 05:11 AM
WTB 2 Sphere 80700 racer34v R/C Items: Wanted to Buy 0 03-05-2008 03:33 AM
Sphere Comp and Sphere TC Differences Paul_67 Electric On-Road 4 08-20-2007 03:27 PM
LRP SPHERE COMP. ESC (80700) + 13.5 wannabee R/C Items: For Sale/Trade 15 02-10-2007 05:25 PM
