LRP SPHERE COMP. ESC (80700) >
Old 06-06-2007, 05:32 AM
  #496
J.Gonzalez's Avatar
Trader Rating: 16 (100%+)
I am trying to determine if their is any difference in profiles or internal hardware, fets etc from the tc spec and the comp 2007 version?
I checked out lrp site and it appears that the features and specs are the same however the touring comes with the fan setup and 12 gauge wire.
Any idea?
Jamie
J.Gonzalez is offline
Old 06-06-2007, 10:50 AM
  #497
burito's Avatar
@senna: the profiles are the same, hardware (incl fet's) are different. doesn't really show when just reading the specs...
@xluis: sounds weird and definitely not normal. can you let me know the speedos settings and gearing you ran?
burito is offline
Old 06-06-2007, 02:24 PM
  #498
xluis's Avatar
Yes, i use a 07 ESC version, not ISTC, with a program 2-5-0-0 and 2-4-0-0, and final ratio 7.3, with foams tyres, rollout 25.5 mm.
I probe ratio from 7 to 7.5, and rollout 25-27mm, with 5 cells. Batteries VTEC4200.
Temperature 26, track 38.
Thanks.
xluis is offline
Old 06-06-2007, 04:58 PM
  #499
drew85's Avatar
will this speedo work with novaks motors? I was looking to run the 19t.
drew85 is offline
Old 06-06-2007, 05:41 PM
  #500
i think, speedtechrc just got some in stock.
mugenracer is offline
Old 06-06-2007, 06:24 PM
  #501
drew85's Avatar
drew85 is offline
Old 06-07-2007, 02:39 AM
  #502
burito's Avatar
@xluis: your settings sound about right when using the X11 4.5t. Do you make use of the "internal temp check system"? If so, how many flashes do you get after the run?
Also, I assume you use a cooling fan on the speedo, right? That should not actually be the cause for your fading, but it's always better to run a fan.
If nothing helps, I'd recommend you try a friends motor (if possible) to see if this would fix the problem, so you know if it's speedo, motor or something else. If you think it's the motor, you should try replacing the rotor first.
Hope this gets you further.
burito is offline
Old 06-07-2007, 06:30 AM
  #503
xluis's Avatar
Ok, thak you very much. In the next week, i buy a 4.0 and probe it. I dont use a fan in the speedo, because the internal check temp have 10-12 flashes, and in the ext is to 70-75C.
Thanks.
xluis is offline
Old 06-07-2007, 06:44 AM
  #504
Originally Posted by nnick View Post
It's 293.1 Surprisingly comes quite expensive but we offer no shipping charges around the world for this amount
currency conversion http://www.eurocambi.com/
Nick
Let's just say $400 is not really a competitive price
cvt01 is offline
Old 06-07-2007, 08:10 AM
  #505
Shop Owner
nnick's Avatar
Yes, I know but don;t compare prices from Europe with US. Always US market is cheaper than European for some reason (maybe bigger market).
This specific product for some reason is expensive compared with others from LRP. I have notified the distributor and wait for their answer
nnick is offline
Old 06-07-2007, 09:00 AM
  #506
Tech Legend
Wild Cherry's Avatar
Originally Posted by xluis View Post
Hello to all, I have had a bad experience in the last National race with a motor X11 4.5, I feel, the yield loss on the 3 minutes of race. I have a pole position, and exit with number 1 in the Final A, in the exit very fast, distanced to me of 2 until the minute 2.5 - 3, that the motor it seems to have fade, ending a temperature of 84, measured with a Exergen 301. I like to know,if somebody to experienced something similar, seems that it has lowered the magnetic field, is possible that single it is necessary to replace the rotor. somebody can help me? Burito?.
Pd:The motor is fantastic, very powerfull, and in this conditions i finish in 3 place. The question is only, for secure me, is i have to replace the rotor.
Thanks in avance.
Suggest you take the motor apart and inspect the rotor to see if the kelvar thread has not begun to unglued and cause drag on the motor...
Also check the bearing`s...
Wild Cherry is offline
Old 06-07-2007, 03:41 PM
  #507
xluis's Avatar
Ok, i inspect the rotor and i dont see any strangle, but i inspect more slowly, thanks.
The bearings are news, ceramics bearings.
xluis is offline
Old 06-08-2007, 12:26 AM
  #508
burito's Avatar
@Wild Cherry: I think you missed that he's using an X11 4.5t, which comes with the sintered rotor. So no kevlar wrapping there which could cause a problem...
burito is offline
Old 06-08-2007, 07:22 AM
  #509
Tech Legend
Default Woops...
Sorry ,
I stand corrective...
Old 06-08-2007, 08:24 AM
  #510
In my 4.5, I had to remove the nylon washer with the ceramic bearings...
With the washer the motor didn't run as he should, and the temperature was higher than before with the standart bearings.
RFrancis is offline
