LRP SPHERE COMP. ESC (80700) >
Old 05-08-2007, 11:41 AM
  #466
You should set the esc in NiMh mode and not Nimh/lipo.
Stevenkoiter is offline
Old 05-10-2007, 10:20 AM
  #467
Miguel's Avatar
sirs,
can the new novak brushless motors e.g. velociti 6.5 sintered and above work with the LRP brushless+brushed version of the sphere esc? the manual states that it can handle motors 5.5 turns and up. am not just sure if it could handle the new brushless motors from novak. thanks in advance
Miguel is offline
Old 05-10-2007, 10:27 AM
  #468
TA05ers's Avatar
Hi all.... anyone can help?
Originally Posted by TA05ers
Guys... need a little help here.
My setup; TA05; LRP Eraser 9.5T; LRP Sphere Comp 2007 Ed; Center one way; Asphalt racing.
Have been using brushed motor, just switched to BL for its obvious benefits.
BUT, I am missing on the drag brake which brushed motor can offer.
Have been fiddling with the 'automatic brake' mode on the sphere. From 0 - 6, still achieve no drag brake. What I need to do to achieve some form of brushed mot feel?
1) Have I been fiddling with the wrong mode? I am sure the Sphere can offer much more. Please help!
(the folllowing two questions will digress a little from the thread topic)
2) i think the one-way plays a part in this. Is it not advisable to use one-way for BL motor?
3) Do I have to use spool or direct coupling? What is the difference anyway?
Thanks!
TA05ers is offline
Old 05-10-2007, 01:50 PM
  #469
Originally Posted by Miguel
sirs,
Yeap i think that it will work ok , will you use sensor?? , i don't know if novak velociti 6.5 can handle sensor that's why i am asking!!
Zacharopoulos is offline
Old 05-10-2007, 01:55 PM
  #470
Thanks!
Answer to :
1) yeah it can offer much more brake , but with sintered magnets that 5.5T and lower, uses.
2) of course spool or diff can change the feel of the brake , but is something more than advise or anything... it's up to you what you will use. Something that will fit your track , and your driving style.
3) you don't HAVE to use anything , as i said above!! which difference??
Old 05-10-2007, 05:32 PM
  #471
Miguel's Avatar
yup, novak motors already come with the sensor wire installed. thanks!
Miguel is offline
Old 05-11-2007, 12:01 AM
  #472
Then it should be ok , the only thing that it may not be safe is using it without the sensorwire , but now it will be ok..
Old 05-13-2007, 07:12 AM
  #473
ROBORAT's Avatar
Originally Posted by ROBORAT
..... oh, and when running brushed motors, i assume schotky diode would be required? i have the novak ones, those should do fine right?
so would it be ok to use an external schotky diode when running a brished motor with the sphere tc? i plan to solder one of the novak super schotkys directly to my 27T motor tabs. would appreciate any info on this. thanks!
ROBORAT is offline
Old 05-13-2007, 06:10 PM
  #474
TA05ers's Avatar
Answer to :
Thanks for the advice Zacharopoulos..
TA05ers is offline
Old 05-15-2007, 06:11 PM
  #475
ROBORAT's Avatar
any feedback on this would really be appreciated ... i dont wanna fry my sphere while running brushed.
burito?
ROBORAT is offline
Old 05-15-2007, 11:52 PM
  #476
Stein Tumert's Avatar
I have done that without any problems...
Stein Tumert is offline
Old 05-16-2007, 03:20 AM
  #477
ROBORAT's Avatar
Stein: thanks for the response! will try it out this weekend.
ROBORAT is offline
Old 05-18-2007, 07:24 PM
  #478
Scott B's Avatar
Trader Rating: 45 (100%+)
Hey Burito, I was wondering if the newer Vector X11 motors have been givin to ROAR for approval???
Scott B is offline
Old 05-22-2007, 09:53 AM
  #479
Tech Legend
Wild Cherry's Avatar
I`v been running a x-11 for a few month`s now ..
It started to get bit noisy , making a kind of grinding noise....
So I took it apart and discovered the pinion side ball bearing had seen better days ...
so...
I replace both bearing`s with new ones and it is nice and quiet again ...
Like brand new motor again....
Wild Cherry is offline
Old 05-22-2007, 10:37 AM
  #480
TA05ers's Avatar
Hi, this may be the wrong thread to post this. But just a short question.
My Eraser 9.5T is not turning smoothly, seems a bearing or two is loose. Thought of taking it apart to check, but after removing the 3 back screws and I dont see any other screws keeping the motor together. Any idea on how to fully disassemble this baby?
Please help!
TA05ers is offline
