LRP SPHERE COMP. ESC (80700) >
Old 04-22-2007, 02:41 PM
  #406
Originally Posted by Wild Cherry
I`m not positive but it seems you thermaled...(Too hot)..
Check gearing
Check if you have the ADPC mode (mode 2), if it is set to high...
Use the heat sink ...
hmm it was pretty cold those days, maybe 15 degrees (celsius), and i was not really pushing it to the limit and TC spec comes with heatsink and fan preinstalled soi hardly can imagine that the damn thing burnt
ADPC mode is set to 2, initial brake is 0 and automatic brake 1
omoser is offline
Old 04-22-2007, 02:44 PM
  #407
Originally Posted by Zacharopoulos
Do you experience any glitching???
If you have changed the timing than may be a timing problem otherwise no.
But if you have any other motor that you can try then try it , it maybe is a motor prob.
no i did not change the timing of the 4.5T, i should receive a Vortex 3.5 in some days and check whether its the motor or not. I dont really experience any glitching, its just that the leds sometimes flicker at neutral position.
But before all these set again your speedo and set again the modes and don't use any expos at throtle -brake at the transmitter and if you can, set speedos drag and initial brake at 0!!
hehe that was the first thing i tried, unfortunately without any success
omoser is offline
Old 04-22-2007, 02:55 PM
  #408
yeap i had the same problem but at the same time that the leds got crazy the motor lost power and the ok and then again lost power..
Don't want to scare you but if you experience this only at FULL throtle then it is speedo' problem!!
I had my ISTC (nosram) burnt at the second battery after all this that you describe...
well... you scare me i actually do not experience this "flickering behavoiur" at full throttle only, but also when slowly accelerating. and even better, there is one more strange situation: Sometimes, the rotor stops and when i hit throttle again nothing happens except the MODE LED blinking red+yellow and the SET LED is constantly blue.
I tried a lot of things, even switch from spektrum DSM to normal FM radio to see if there is any difference...
So you think the speedo is broken? Should i disassemble the motor and check if there's something broken? This is my first brushless season so i have no idea where to start
thank you very much for your help!
omoser is offline
Old 04-22-2007, 02:57 PM
  #409
ah yeah forgot one more thing, it may no make any difference but it's a Nosram TC Spec, not the blue one
omoser is offline
Old 04-22-2007, 04:32 PM
  #410
AI2
Hey oliver
i've seen that before, it was a bad sensor connection, so check that the sensor cable is ok. Otherwise it could be a bad hall sensor inside the motor! In which case you have to send it in for service. best way to check this is to try it with another motor.
hope this helps.
AI2 is offline
Old 04-22-2007, 05:00 PM
  #411
Ballsie's Avatar
Originally Posted by Guo Chean
Hey Burito,
do you know what profile of the TC spec that Surikarn runing in TITC since he runing orion brushless combination with TC spec?
I'd like to know the answer too
Ballsie is offline
Old 04-22-2007, 07:40 PM
  #412
HI OMOSER
I think is the motor problem, in Hong Kong , the first batch X11 4.5t have some motor issue, someone broken just a few second racing, someone broken a few pack, someone have problem like your case. We sent all the problem motor to our distributor but I dont know motor have warranty or not. Just waiting the distributor feed back.
G2B Anthony is offline
Old 04-22-2007, 08:27 PM
  #413
Kenneth Tan's Avatar
Originally Posted by G2B Anthony
HI OMOSER
Hi, all of the problems are related with motors? Nothing with the esc? Thanks.
Kenneth Tan is offline
Old 04-23-2007, 12:47 AM
  #414
you said that sometimes rotor stops. at this point if you pull the throtle nothing happens right??? if simultaneously , pull the throttle and push the car , will it start turning???
Zacharopoulos is offline
Old 04-23-2007, 12:50 AM
  #415
Even if you open the motor you won't find anything , something missfuctions maybe the inside sensor of the motor!!
But if you have any fridthat has a BL and works , try your motor with his speedo and your speedo with his motor. it will be easy to understand what is wrong.
But i would like you to answer my previous question cause i had the prob i described....
Old 04-23-2007, 02:21 AM
  #416
yes exactly, and at the same time the MODE LED is blinking red+yellow and the SET LED is constantly blue, maybe this is some kind of error code??
omoser is offline
Old 04-23-2007, 02:43 AM
  #417
HI OMOSER
hmm maybe it's really the motor, now that you say it i think the motor sounds different than in the beginning... thanks for the tip! I will try to get hold of another motor and see what happens I'll keep you posted
omoser is offline
Old 04-23-2007, 03:23 AM
  #418
That's exactly the issue , as fas as i know is a problem with the inner sensor of the motor;.... but i haven't heard anything for the 4.5. i had this prob with ONLY 3.5
Old 04-23-2007, 08:59 AM
  #419
Tech Legend
Wild Cherry's Avatar
Read your instruction`s .....
The codes are listed ....
Look for the multi-protection system code...
Wild Cherry is offline
Old 04-23-2007, 03:47 PM
  #420
hmm there is only one thing about TSD in the instructions, only the Set LED would (should?) flash in this case.
omoser is offline
