LRP SPHERE COMP. ESC (80700) >
Old 04-10-2007, 04:11 PM
  #346
Sam_Smith's Avatar
Just through riding the curbs hard and fast Didnt have any big accidents or anything. I was very suprised when I saw it
Sam_Smith is offline
Old 04-11-2007, 02:10 AM
  #347
Ali Graham's Avatar
My endbell has also cracked, this time around the top right screw. Nothing serious, just a result of hard and fast outdoor racing. I also managed this, and this is a bit more serious!:
Ali Graham is offline
Old 04-11-2007, 09:00 AM
  #348
floodo1's Avatar
At what point would i need to switch from 16 gauge wire to 14gauge?
Is 16 sufficient for Lipo 4300 in an oval car?
I have previously asked and reto said that 16gauge was sufficient for 4cell 4300, but now I have switched to Lipo
floodo1 is offline
Old 04-11-2007, 11:35 AM
  #349
Can I use the TC spec with 14 gauge cable instead of 12 gauge?? I am running 5 cells and 3.5T & 4.5T
harris is offline
Old 04-11-2007, 03:24 PM
  #350
If by the word "endbell" mean only the plastic cap then you just overtight it. These 3 screws don't need to be very very tighten cause only keeps the timing at position nothing more.
but it's very interesting if you cracked the other piece of endbell and i would like to see a pic!!
this thing with the "armature" ( magnet) is just a manufactire problem. a friend of mine managed to break the axle at the point that the pinion locks
Zacharopoulos is offline
Old 04-11-2007, 11:36 PM
  #351
A Ilievski's Avatar
Trader Rating: 39 (100%+)
ok ive looked and looked, where can i get a LRP TC Spec from. Im in australia so they must ship to Australia.
A Ilievski is offline
Old 04-12-2007, 01:25 AM
  #352
check www.rcring.com , he ships worldwide and he just received TC spec
Old 04-12-2007, 01:57 AM
  #353
Shop Owner
nnick's Avatar
TCs run out but it's only a matter of few hours (LRP distributor is very close) to get more so don't be dissapointed when you see Out of stock
nnick is offline
Old 04-12-2007, 08:23 AM
  #354
Iceracer's Avatar
For off road, do you find a problem with dirt getting into the holes for the mode switches and leds? Do you cover them with tape?
Iceracer is offline
Old 04-12-2007, 05:35 PM
  #355
Ali
We had a few rotors go at the TITC, Reto advised that it was due to getting too hot at high rpm, we replaced the rotor and added a motor heatsink and all was fine.
Besercoe is offline
Old 04-13-2007, 01:36 AM
  #356
This should be an issue with previous motors and not sintered magnets!!
I broke 2 magnets , because the same reason as Reto told you , but it was 5 star or 5,5T with no sintered magnets!! And it was also prototype motor.
After that they sent us sintered magnets and everything was perfect!!
This is due to the fact that sintered magnets gives more torque and Less RPM's.
Previous magnets were broking due to hi RPMs and not temp!! even if a magnet has 300 celcium degrees won't broke , but it can be broken cause of extremely RPMs even if it is cool enough
Old 04-13-2007, 05:42 AM
  #357
This is due to the fact that sintered magnets gives more RPMs and Less torque!
Previous magnets were broking due to hi torque and not temp!! even if a magnet has 300 celcium degrees won't broke , but it can be broken cause of extremely torque even if it is cool enough
I would of thought it was oposite... arent bonded magnets weeker? If that is the case they should have less torque. I also thought that bonded were inherentely less reliable because of their constrution, hence the overheating problems with those rotors, but i guess im wrong...
Itchy is offline
Old 04-13-2007, 01:28 PM
  #358
Yeap itis right that bonded are weaker as a material , but if i can explain it right it has more torque than a sinterd magnet , that's why they using a diff gear ratio!! maybe i am a little confused so i will try to think it and explain it better later with a clear mind!!
Old 04-13-2007, 04:13 PM
  #359
Sintered has more torque and less RPM, that is why we have to use bigger pinion, to make more RPM.
Sintered does not break as easily as bonded because the material is stronger.
Hagberg is offline
Old 04-13-2007, 05:57 PM
  #360
Sintered does not brake as easily as bonded because the material is stronger.
That's right , it is exactly the opposite from what i said before! Sintered=More torque and less RPM , it was a misstranslation from Greek to English!!
but i don't think that bonded brake easier because i remember that when i raced with bonded i used 2 degrees of autobrake and now with sintered 0 degrees for being equal to a brushed motor. But i may be wrong because i also ued different spec speedos!! Sphere comp-matrix 2007- TC spec
