LRP SPHERE COMP. ESC (80700) >
Old 03-15-2007, 12:05 AM
  #241
akuhon's Avatar
Will this ESC (Sphere Comp TC 80750) work with this receiver ?
akuhon is offline
Old 03-15-2007, 12:27 AM
  #242
why not
G2B Anthony is offline
Old 03-15-2007, 04:10 AM
  #243
akuhon's Avatar
Originally Posted by G2B Anthony
why not
'Cause it's an old RX .... I thought the Sphere will demand new type of RX ....
akuhon is offline
Old 03-15-2007, 10:54 PM
  #244
Trader Rating: 15 (100%+)
Does lrp have a brushless motor close to the 13.5 out yet?
AARON YOUNG is offline
Old 03-15-2007, 11:09 PM
  #245
STLNLST's Avatar
Trader Rating: 29 (100%+)
keep cutting your motors until they do....he he he
Good luck this weekend.
STLNLST is offline
Old 03-15-2007, 11:57 PM
  #246
The X11 13.5T has been available here in Europe since beginning of this week.
jarkko is offline
Old 03-16-2007, 02:57 AM
  #247
Hello Guys,
One Fast Question, I am running the 2007 edition with 4.5T, i can get my hands on a 3.5T motor, do you think that i will have a problem with the 2007 edition????? or i have to wait for the TC before i race with the the 3.5T??
Also what is the difference in the gear ration between 4.5T and 3.5T.
harris is offline
Old 03-19-2007, 02:48 AM
  #248
X11 3.5t not yet release in HK
X11 4.5t 7.8-8.8
Besides, does anyone know how to set up and release the info by the internal temp check system??
Old 03-19-2007, 05:17 AM
  #249
ROBORAT's Avatar
X11 4.5t 7.8-8.8
the 7.8-8.8 final drive ratio is for 6-cell i pressume? sorry, just making sure. cant wait to get my hands on the tc spec and x11. thanks in advance!
ROBORAT is offline
Old 03-19-2007, 05:46 AM
  #250
From memory: press brake for couple of seconds after the run. Turn off the esc. On the pit, turn on the esc WHILE pressing MODE buton. Count the number of flashes. Every flash over 5 means 8șC bellow thermal shutdown. Last time i checked counted 15 flashes. So, 15-5=10 flashes. 10x8= 80șC bellow thermal shutdown
BTW, that was with X11 4.5, geared to 8.1 on large track. air temp around 18șC
Itchy is offline
Old 03-19-2007, 08:34 PM
  #251
Still Bill's Avatar
Trader Rating: 16 (100%+)
I now have the LRP Sphere Comp 2007 (from Hong Kong) with my Novak 13.5 (original version with adjustable timing) in my carpet RDX.
At the Region 12 carpet championships this past weekend, this combination was unbelieveably fast. My car was noticeably faster than my competitors in Brushless 13.5 class on the 96' long back straight and still had plenty of poop in the infield.
Finished second to a really good sponsored driver. Waaaay above where I normally would finish with these guys. Love this combo. Goodbye brushed motors.
Still Bill is offline
Old 03-19-2007, 08:38 PM
  #252
James35's Avatar
According to Charlie from Novak, nothing has changed with the timing ring other than the color.
James35 is offline
Old 03-19-2007, 08:41 PM
  #253
The 7.8-8.8 final drive ratio is for 6-cell
Yes
Itchy
Thanks for your info
Old 03-19-2007, 09:05 PM
  #254
Still Bill's Avatar
I thought I read on the 13.5 string that the new red ring has locked timing.
Old 03-19-2007, 09:11 PM
  #255
James35's Avatar
From this thread:
Originally Posted by Charlie
Hey Guys,
The timing of the our motors is a "non issue" and from my talks with the other manufactures their motors are in the same boat.
Turn the timing all the way up, the motor gets hotter, turn it all the way down, it stays cooler. These are Not Huge changes. It's like gearing up or down a tooth for the most part.
BL motor timing is NOT as effective as regular motor timing. This will be very hard for people to beleive and already assume we're lying, but many guys have experimented with this under controlled conditions and have come to the same conclusions we have.
The timing setup is no different on ANY of the Novak motors. They all have the same adjustments. The statemetns about the colored rings are for indentification, not to state they are not adjustable.
Now you're right, there is "some" effect of timing, but its' not enough to make the motor any faster. It is very similar like gearing up a half tooth, or gearing down a half tooth. Power of the motor is the power of the motor, the timing in BL simply moves the max torque and RPM around a little bit.
In the Faster motors like the 3.5 and 4.5 there may be more effect of the timing, but not from what I've seen working with racers/drivers/customers.
Adrian, if you'd like to actually know why the motors are different, feel free to email us anytime. You can always ask us directly instead. We're only an email away. Its not always about who's the fastest. The two motors are designed differently, going after different things. I'm sure you've heard alot, but get some facts when you can.
I can see bearing upgrades possibly helping, but the timing thing is a none issue, what ever you gain, you'll loose from someplace else. It's physics.
But let's not get off topic on the 13.5 in this Sphere Competition thread. Instead, continue the 13.5 conversation in the New 13.5 Pro thread.
James35 is offline
