Old 03-26-2006, 03:10 AM   #1
Helix70's Avatar
Default Question about battery voltage
Hi all,
I am a nitro guy, but I am curious. I see everyone asking what voltage batteries for sale are. What is the difference? I know it is important that the cells are all the same so they all discharge at the same rate and not reverse the weak cells, but is that it, or are other numbers important, and why? Anyone want to do a battery 101?
Josh
Helix70 is offline   Reply With Quote
Old 03-26-2006, 03:45 AM   #2
That0neguy's Avatar
Try here.
Hello.0
That0neguy is offline   Reply With Quote
Old 03-26-2006, 03:56 AM   #3
Helix70's Avatar
If you don't know, don't post.
Old 03-26-2006, 04:16 AM   #4
if u run stock you want high voltage.
whats high voltage mean? it means the voltage the battery is when it is put under load. in many cases either 30amps or 35amps.
higher voltage = more power
if written on the pack is rate 1.20volts.... that means the average voltage is 1.20volts when discharged from its peak to 0.9volts
noobie is offline   Reply With Quote
Old 03-26-2006, 04:19 AM   #5
Helix70's Avatar
Ahh ok.. So what are good numbers? What are average, and what are crap ones?
Old 03-26-2006, 08:01 AM   #6
josh69162's Avatar
Send a message via AIM to josh69162
When GP3300's were the main cell, really strong packs were in the 1.19 range, while good packs were in the 1.18's. Modified racing packs were higher runtime packs, but with 1.17 voltages. Now, we are spoiled, and get insane runtime with 1.205ish voltage. That seems to be the typical number. I haven't really seen anything above it, but not much below it, either.
-Josh
josh69162 is offline   Reply With Quote
max battery voltage? joe of loath Rookie Zone 3 05-27-2007 06:18 AM
Battery Peak Voltage Question imel24 Electric On-Road 1 04-20-2007 03:59 AM
Battery voltage maskedrider Nitro On-Road 8 01-29-2006 07:49 AM
Battery Voltage? dragster Australian Racing 26 12-26-2003 04:14 AM
Battery voltage shortyzz Rookie Zone 2 11-21-2003 01:12 PM
