Like Tree299Likes
XRAY T4'21 Spec
Old 06-25-2021, 11:57 AM
  #331
Hi folks, a guy at my track purchased a used T4, and it came with this triangular arm configuration for the front.
Does anyone know what bulkheads that are, and where to buy it??
Xtracrispy is offline
Old 06-25-2021, 05:53 PM
  #332
That was made by Yeah Racing. It stiffened the caster block and I found it added more steering.
mooby64 is offline
Old 06-25-2021, 06:01 PM
  #333
I found the yeah racing camber links, but not the metal bulkheads themselves on the YR website.
Are you able to provide a link by any chance?
Old 06-25-2021, 07:35 PM
  #334
I tried this set up on an 2018 T4. It worked with the stock bulkheads. lt attaches at the camber holes, and where the upper deck is screwed to the bulkhead.
mooby64 is offline
Old 06-25-2021, 08:11 PM
  #335
R Dodge's Avatar
The parts on the car pictured are from prolix. He had his own alum. upper bulkhead clamps and the outer eyelet was 3d printed. Not sure if this is in production anymore
KE4PJO likes this.
R Dodge is offline
Old 06-26-2021, 10:07 AM
  #336
KE4PJO's Avatar
https://www.prolixrc.com/product/equalizer/
KE4PJO is offline
Old 06-26-2021, 03:06 PM
  #337
Thanks for the links guys, there's no way I would've found that otherwise.
After some digging, the designer seems to put a 3d printed plastic version up on shapeways for half the price:
https://www.shapeways.com/product/MV...41950&li=shops
Any thoughts on the utility/performance of a triangular setup?
I was actually initially wanting it for durability reasons, thinking that if the C-hub had more support, it'd be less likely to break.
The knuckle would also get more support from the upper joint, so less likely to torque and snap off at the bottom.
The trade-off I think, is the possibility of tweaking the bulkhead inward in a really bad crash since it's now carrying lateral loads at an offset.
Old 06-26-2021, 08:10 PM
  #338
KE4PJO's Avatar
I ran that setup on every T4 from '16-'19, it really improved the steering consistency. The car just felt solid...
KE4PJO is offline
Old 06-28-2021, 09:14 AM
  #339
R Dodge's Avatar
Xray plastic is extremely durable so I don't think you need this for durability reasons. I can say from experience that the 3d printed eyelets on the outside are sloppy when new and just get worse really fast. You'd be replacing them often which gets annoying. This assembly can affect how the car feels in the corner, but the '20 & '21 do have a more responsive feel than the '19 and older models did so I don't think it is necessary. Finally, none of the team use these parts and I haven't seen them on any non-team cars at any tracks I've visited since the '20 came out. So copying setups or getting setup help from others could be tricky.
Best bet IMO is to just stick with the Xray design. As far as your buddy goes, I'd say it's fine to run it as is for a while so he can enjoy the car, but to plan on replacing those parts with Xray at some point soon.
Ggrant and gwc like this.
R Dodge is offline
Old 08-13-2021, 12:24 PM
  #340
Dan
Dan's Avatar
Trader Rating: 74 (100%+)
https://www.thercracer.com/2021/07/a...f420-bd10.html
Anyone try the Axon wheel hubs on their T4? (awesomatix style) Thoughts if worth the upgrade?
Dan is offline
Old 08-13-2021, 02:16 PM
  #341
Airwave's Avatar
I'm using them. The assembly is mechanically correct. I still have doubts about the bearings lifetime...
Airwave is offline
Old 08-13-2021, 02:17 PM
  #342
Airwave's Avatar
You don't want to do that. It will totally remove the adaptative caster of the car.
Airwave is offline
Old 08-13-2021, 02:21 PM
  #343
Dan
Dan's Avatar
Oh my Awesomatix which take 6x10 bearings, they required a little more replacement/maintenance but not extensively so.
What are your thoughts on performance? Worth it?
Dan is offline
Old 08-13-2021, 05:50 PM
  #344
Airwave's Avatar
I though that the axle were a mm smaller on the awesomatix so it was using standard bearings (10x5x4). It is not the case?
About the performance I'm not sure, Maybe the transmission is a little bit more free...
Airwave is offline
Old 08-29-2021, 06:08 AM
  #345
Airwave's Avatar
A friend recently made me realize that the motor is constraining the torsional flex of the car. As the motor mount is aligned with the upper deck, there is a constraint when you flex in a way that you don't have in the other way.
To solve this issue I had to add 2mm washers between the motor and the motor mount. Washers are pretty small and it makes the risk of the motor moving greater.
How are you guys dealing with this issue? Is everybody using an asymmetric upper deck?
Airwave is offline
