XRAY T4'21 Spec
#151
How does the shorty pack fit? I'm just getting back into on-road my last touring car was a xray T2' 007
Last year I purchased a new xt2c 2019 and the last time I raced a stadium truck was 2007. Wanted to see if any of my current shorty packs would work in the new 2021 cars.
Just want to get back into on road cars.
#152
ThAnks for sharing your set up Mark. It was fun watching you race.
#153
Hey Xray Drivers,
What is the handling difference in the rear between 3 degrees toe in board pin and 1 degree block with 2 degrees in?
Thanks and God Bless,
B
B
#154
If you switch to a car that has 9mm longer arms and you "crash less", it's either the setup that is (miles) better, or the car that is more "mechanically sound", or the assembly that went better, or the driver that improved, or...
But not the 9mm or the MM structural side of things... I'm sorry, it's just not. Had the T4'19 been a shitty ill-handling platform, I could agree, but it sure wasn't a dog of a car that would snap on you anytime at all. This was the case when cars were evolving 25 years ago and people would go from a Yokomo M2 to a MR4-TC... HUGE technical changes, and change of materials, and change of layout, and.... like quantum leap.....
The '20 had a lot more steering and I could get it through the corners whilst being less aggressive, and last but not least, it was faster.
#155
The purpose of this is so the rear arm pins aren't bound as much at the 3 degree angle. Running the rear pins at a 2 degree opposed to 3 degree will allow the rear arms and suspension to operate more efficient, less mechanical resistance so to speak. Also in return will generate slightly more rear grip and a more consistent chassis.
#156
When the '20 first came out I ran it back to back with the '19 (during one practice run) with the brand new set of the same tyres on each car, and even switched the bodyshell between cars to keep everything the same.
#157
Let me try again.
The pre-MM T4 cars are a very mature, consistent platform, and not crashy cars that snap on the driver like a $99 aliexpress RTR touring car.
I am saying that if you are "crashing less" it means that you were "crashing" before. If you crash often enough with a T4 '19 to notice such a change, it means that the previous car was "ill", either because it was not mechanically sound, or because your previous setup was miles outside of the setup window, and I mean not just half a millimeter of roll-centers up or down or whatever but more like totally f'ed up with . So really the delta between new car and old car setup is miles apart because the previous one was miles off, not because the new one is inherently miles better per se.
If we try to quantify the average lap times improvements from Joe Schmoe Driver by going from the T4 '19 to "new T4", it's probably at best a couple of tenths per lap. I know, I own both. Granted, this is big enough if you're playing the top of the A-main, still keep in mind we are talking 1% or 2% on a 10s lap here... not a quantum leap like "crash less".
For the record, last time we raced pre-covid, one of the local hotshoes had just purchased a new, heavily discounted T4 '19 and he won with it, including the other local hotshoes that he usually races with (and who also sometimes win, too) with the newer 800MMX and T4 '20's. This is not to conclude that the T4 '19 is better, but rather that there is less of a difference between the older and newer T4 platform than marketing and the internet would like you to believe.
Hope this helps explain it.
#158
#159
#160
Not at all... The inner rear arm pins will have 1 degree less angle allowing the arms/suspension to operate in a much smoother manner. The outer pivot joint you ask about remains the same as we are replacing the outside zero degree hub with a 1 degree hub so this doesn't affect the movement of the outer pin. Hope this helps
#162
#163
#164
Drivers are using the ARS on the asphalt so this will eliminate the use of a 1 degree hub all together. However with the ARS I've seen team guys narrow down the rear suspension pins to 1 degree as you get full toe adjustability on the ARS with the turnbuckles.
#165
