Old 03-25-2006, 10:54 AM   #16
stumper1's Avatar
R/C Tech Charter Subscriber
Originally Posted by killingtime
I'm having Deja Moo, the distinct feeling that I've read this bull before.
I'd be interested in seeing the reviews after the T2 has been out as long as the RDX to this point.
By then shouldn't we be running the T-4?
I have both and they are both great cars.
stumper1 is offline   Reply With Quote
Old 03-25-2006, 12:24 PM   #17
vabroom's Avatar
typical standard answer:
1. They are both great cars!
2. Ask the people who race at your track
3. If you can try drive each one to see if it suits your style of driving
4. Whichever your LHS carries parts for
5. If you don't want to support your LHS and buy online then make sure you have spares - it make be sometime before you get your order
RC racing is still trying to prove that two solid objects can be in the same place, at the same time.
vabroom is offline   Reply With Quote
Old 03-25-2006, 01:20 PM   #18
ChadCapece's Avatar
I can give a pretty unbiased answer for this question:
I've driven and worked on the RDX and the T2.
1. The Corally is much more brittle than the T2.
2. The Corally is very aggressive and will still perform well if you like to over-drive the car.
3. The T2 is MUCH easier to work on. It's almost as easy as the Yokomo BD or Cyclone.
4. The T2 is more durable.
5. Parts are slightly cheaper for the T2.
6. T2 has a better manual and is a better value for anyone that races on carpet and/or medium to low traction asphalt.
7. I would pick the Xray T2 over the Corally b/c it is easier to work on and the chassis can be tuned with just adding or removing screws. It costs well over 50 dollars and about an hour of wrenching to change the stiffness of a Corally chassis.
ChadCapece is offline   Reply With Quote
Old 03-25-2006, 07:54 PM   #19
tbeardmore's Avatar
T2..... does anyone know what that stands for...???
Oh yeah.... I remember now.....
TWEEKS 2 EASY??
TWEEKS 2 MUCH??
just joking guys - don't take it tooooo seriously...
and when someone tells you that an RDX is too fragile --- it's only when you stuff a board and the A-arm breaks (by design). If it didn't break - then it might tweek the chassis.
BMI DB10R, Corally RDX PHi, BMI 12R..!!
Need a "real" car... contact me at:
www.beardmorechevy.com -or- www.beardmoresubaru.com
tbeardmore is offline   Reply With Quote
Old 03-25-2006, 08:09 PM   #20
ChadCapece's Avatar
So true!!!! The arms are too brittle to absorb enough impact to tweak
Old 03-25-2006, 08:13 PM   #21
Super Moderator
Trader Rating: 17 (100%+)
Isnt RDX short for Really Delicate Xray???
Tekno|JConcepts|TeamTrinity|BOOMrc
Bob Barry is offline   Reply With Quote
Old 03-25-2006, 09:03 PM   #22
stiltskin's Avatar
Trader Rating: 102 (100%+)
F(irst) K(it) in 05
T(he) 2(nd)
Tony Rumple
Team EAM // Gravity RC
stiltskin is offline   Reply With Quote
Old 03-25-2006, 10:07 PM   #23
BlackKat's Avatar
Sorry but I have to call HORSECRAP here....LOL
You can have a full box of broken T2 parts before I've even broken a thing on my RDX. Most mistake a lot of guys make is not buying the Specialized bumper kit. The stock bumper looks more suitable for kitchen use (see: sponge)
BlackKat is offline   Reply With Quote
Old 03-25-2006, 10:15 PM   #24
I too would have agree that the RDX is more fragile from what I've seen.
At this years US Indoor Champs, they even nic-named one of the areas
of the track "RDX Corner"!!
John Warner is offline   Reply With Quote
Old 03-25-2006, 10:33 PM   #25
syndr0me's Avatar
Trader Rating: 32 (100%+)
Okay, lets put this arm thing to rest. It's like this:
The current RDX arms are more fragile than those you find on other touring cars. While we all agree it's preferable to break an arm over bending a bulkhead, it's well-documented that these arms are more fragile than other cars with strong arms that don't bend bulkheads. People can deny this if they want, but deep down they know it's true.
You can mitigate a lot of the trouble with arms by using the SRC bumper (see also: "The Shovel"). The fragile nature of the RDX arms is because of a design compromise more than anything. You see, the arms on ALL 4 CORNERS of the car are exactly the same. Front to back, right to left. It's extremely convenient.
Corally has had aluminum arms available for a long while that are considerably more durable, though most people prefer not to use them for various (good) reasons. Also, Corally will be releasing new arms in the very near future that are designed to be much stronger, and will likely be on par with what you get when using cars from other manufacturers. These arms are not the same from front to back, so you'll lose that convenience, and will need to stock them for both ends of the car. These arms are not intended to replace the current arms (which work fine, and have been used to win a trophy or two in the last two years), but rather, are offered as an option part to people who feel the existing arms are too fragile.
Again, they're both very capable cars, as we've all said a million times. The T2 has a lot of modern conveniences that make it very flexible (some pun intended) for multiple surfaces, and quite easy to work on. It's also going through some growing pains, which is sort of the norm for XRay since they release cars at such an incredible pace.
The RDX has the benefit of nearly two years of refinements under its belt. The RDX you buy today should be called the RDX 1.5, since it's got quite a few upgraded parts from the original kit. It's also managed to remain competitive in the face of at least one (and sometimes 3) major releases from every other touring car manufacturer.
Both cars are expensive, and the parts are expensive as well. If you can find the parts at a dealer (stormer, a/b, speedtech) you'll save a few bucks. Running either of these cars will cost you some cash, especially if you stock your own stuff. These are smaller companies producing cars with a higher production cost in lower quantities. That's how it works for "luxury." Check out the prices of parts before you buy one, otherwise coming here to bitch about the cost will make you look like a dick, as I found out myself. If you're racing on a small budget, go get a nice used Xray FK05 or new Tamiya TA05 with a few hopups. The FK05 is a damn fine car, can be had for cheap, and shouldn't need too many parts since it's fairly durable. The TA05 is cheap, the parts and hopups are cheap, and it's a great performer.
syndr0me is offline   Reply With Quote
Call tmunno Florida Racing 1 11-18-2007 06:52 PM
Call of Duty 2 RiceEatin1995GT Chat Lounge 2 10-23-2005 09:55 PM
They call this a PRO???? IMPACTPLAYR Electric On-Road 13 02-24-2003 01:11 PM
What do u call those zxt Electric On-Road 6 07-07-2002 06:32 PM
