Mugen MTC2
#1246
Does anyone have a good recommendation for replacement ball studs on the shocks? These seem to strip out far too easily on me. I've seen the Officina ball stud set and that looks to cover the hubs and upper arms but nothing for the shocks.
#1247
I usually use a plastic washer, don't have to tighten the ball as much. Have also stripped quite a few
#1248
Officina does make the smaller (5mm) ball studs... though it may not be the most convenient as they are studs and not just the ball. I make sure that the "studs" at the top (shock tower) and bottom (susp. arm) only stick out 3mm to 3.5mm and are locktited in place. This allows the hex driver to insert deep enough into the stock balls so that it is more difficult to strip them out.
#1249
On the rear, make sure you get the LONG anti roll bar rear ball stud. Because Mugen has the lower shock attached to this, you have to use the stock 5mm aluminum balls. But after replacing all the others with ball studs, you will have plenty of spares left over
See my post here about the ball stud and the set screws... this may help you not strip as many out.
Mugen MTC2
#1250
I used T-Works titanium ball studs on my cars. For the shocks, get the 8mm length ball studs for the upper shock mounts. This gives you maximum flexibility with spacers; the shock mount threads are through holes so the stud length doesn't matter. For the front lower shocks, get the 4mm length ball stud.
#1251
Even using this method they will still stripe. A guy I race with installed the set screws opposite to what the manual says. This allows you to you use 1.5mm allen instead off the 2mm allen. Using this method almost eliminates any chance of stripping the pillow or the set screw.
#1252
#1253
maybe the design is flawless, only the manual is incorrect
#1254
What have you don’t different setup wise between the two classes?
