Like Tree746Likes
Mugen MTC2
Old 11-13-2021, 10:40 AM
  #811
Jochim_18's Avatar
look up Alex Fera on Facebook he makes those bumper out here in cali.
NutDriver likes this.
Jochim_18 is offline
Old 11-13-2021, 10:41 AM
  #812
Jochim_18's Avatar
Marcos J time to do some testing..
Marcos.J likes this.
Old 11-13-2021, 04:22 PM
  #813
Super Moderator
Marcos.J's Avatar
Trader Rating: 235 (100%+)
yes so far very happy with Krazedbuilds new design, I ran the car identical to last month race , tires, motor ,body ,and gear ratio. just swapped chassis. Last month best time in the main was 27 laps 5:11.553 with a fast lap of 11.537 today was 27 laps 5:07.741 fast lap 11.365. I'm racing it tomorrow at another outdoor local track to compare from last weeks times.11
Marcos.J is offline
Old 11-13-2021, 09:26 PM
  #814
Jochim_18's Avatar
Tested the chassis today right away I noticed car has more off power steering and rear end is very stable with same setup. Second run I switch to Yokomo/Axon 2.5/2.8 progressive springs and it is even more dialed.
Marcos.J and dawgmeat like this.
Old 11-14-2021, 08:32 AM
  #815
Dxb430's Avatar
Default Officiana rc bypass oils
I have moved to indoor carpet racing and it is a grey low to medium(by the end of the night) grip level. I have been trying the bypass shocks but think I was very thin on the oil (400cst). The car rolled quite a bit in the front and the front end caused quite a bit oversteer. When using the bypass shocks what range of oils should I be using?
Dxb430 is offline
Old 11-14-2021, 10:18 AM
  #816
at minimum I would double the oil to 800
lk2849 is offline
Old 11-14-2021, 04:40 PM
  #817
Dxb430's Avatar
really???? That seems excessive based on setups I have seen?
Dxb430 is offline
Old 11-16-2021, 08:01 AM
  #818
Super Moderator
Marcos.J's Avatar
Raced the new chassis at this track and went from 13.0-13.1 laps to consistent 12.5's-12.6 ran the same set up as the previous week just swapped to the new chassis.
STLNLST, dawgmeat, Robbob and 4 others like this.
Marcos.J is offline
Old 11-17-2021, 08:01 AM
  #819
sugs's Avatar
So what's different about the Krazed chassis compared to stock?
sugs is offline
Old 11-17-2021, 08:40 AM
  #820
Super Moderator
Marcos.J's Avatar
stock
KrazedBuilds
dawgmeat likes this.
Marcos.J is offline
Old 11-17-2021, 09:20 AM
  #821
stock
KrazedBuilds
In theory the green/aqua areas show the amount of flex the front has and how far back that flex is traveling. The solid blue is 'so to say' flat.
The stock chassis carries a lot of front flex back and in opinion gives the car a lot of steering.
The Krazed Chassis breaks that steering flex up and disperses its energy sooner (behind the motor vs behind the battery) allowing the rear to regain some traction.
But that doesnt mean steering was loss. Going by the numbers it can be retained or even gained a little. But overall the feel should be increased balance from apex to exit and getting on the throttle sooner.
At least thats what I hear from drivers about their designs.
STLNLST, Marcos.J and dawgmeat like this.
Robbob is offline
Old 11-17-2021, 10:22 AM
  #822
Super Moderator
Marcos.J's Avatar
well put in short words in the last 2 tracks i tested it , my laps dropped by a 6-7 tenths per lap
Robbob likes this.
Marcos.J is offline
Old 11-17-2021, 10:53 AM
  #823
STLNLST's Avatar
Trader Rating: 31 (100%+)
on the ARC I was able to run less rear toe-in and still maintain stability as i did with the stock chassis and increased rear toe. My tire wear was also slightly more balanced.
Marcos.J and Robbob like this.
STLNLST is offline
Old 11-17-2021, 01:45 PM
  #824
Iíve ran it with 400 and car was way to soft in the front. Went to 600 and it improved but was still too soft. Will try the 800 next time out and also going to try 400 with piston holes glued closed
lk2849 is offline
Old 11-18-2021, 01:54 AM
  #825
Dxb430's Avatar
have you tried your new chassis compared the the rc maker one? Be interested to know the difference.
Dxb430 is offline
