Old 10-23-2001, 11:39 AM   #16
TRF-Powered's Avatar
What kinda masking tape do you guys use and where to get it???? I use the masking tape I bought from my LHS and it sucked big time with residue everywhere.
TRF-Powered is offline   Reply With Quote
Old 10-23-2001, 11:47 AM   #17
antoniop's Avatar
On the two bodies with thin white lines I used Pactra Flexible masking tape (1/4", 1/8" and 1/2").
The Pro 10 body was done with Scotch Masking tape. The one that the full size painters use, cut with a very sharp Xacto.
Now I'm using Duratrax Liquid mask and it's FREEDOM!!!! Total FREEDOM.
Now my bodies will look like they never did before (of course that after the first crash they'll look like they allways did...)
antoniop is offline   Reply With Quote
Old 10-24-2001, 12:19 AM   #18
imataquito's Avatar
Send a message via ICQ to imataquito Send a message via Yahoo to imataquito
hey nice pic alvin ....
but u REALLY put all ur time into the car dont u ? lol
think its worth it when u see the car which looks like its been freshly painted by the mutsibushi WRC team
but 5 hours 4 stickers is a bit toooooooooooooo long!
imataquito is offline   Reply With Quote
Old 10-24-2001, 03:59 AM   #19
Alvin's Avatar
hehe, imataquito, first time lah, so I very cautious. Even used some denatured alchohol to clean off the lexan before putting the stickers down So that eats up quite alot of time
But seriously, the body making part is alot of fun. If I got the funds I'd get an airbrush and make some really whacky schemes. One of the schemes I like is one that I saw in a tamiya magazine, they had pokemon on the bonnet and doors
Alvin is offline   Reply With Quote
Old 10-25-2001, 12:12 AM   #20
imataquito's Avatar
pokemon car ? lol
i have seen some REALLLY wacky paintjobs and some wicked ones on the track i jus wonder where they get the idea from ...
lol are they THAT creative ? i must b very un-creative then .. personally i prefer simple looking cars or pretty PLAIN looking ones
Old 10-25-2001, 01:36 AM   #21
Alvin,
Does that body fit TB-evo chassis? You seems sto have regular TB01 under that body right?
Old 10-25-2001, 02:25 AM   #22
Alvin's Avatar
imataquito, yeah! That mag is really very cool. I frankly am very sick of seeing stratuses all over the place. If I'm gonna use one of those it's gonna stand out!
TRF-Powered,
I'd guess not because the original tb01 rear body post holes are much further back. I have sinced changed to those with the same position as my TA04.
BUT if u are willing to ream out some new holes I do not see why it won't fit!
Why not get a Skyline or NSX shell? I heard those are good for racing. The EVO 6 is a very very "high" CG kind of shell.
Old 10-25-2001, 11:57 AM   #23
The reason I think that i might not fit is that TBEVO has a really big bumper. Even fitting the NSX raybrig 2000 body needs some trimming to the bumper.... ... I guess I won't bother with it then.
Thanks ;
Old 10-25-2001, 02:00 PM   #24
RCTech Member #2
TSR6's Avatar
Send a message via ICQ to TSR6
Default How to get a perfect cut on a body? ...TSR6's Philosophy..
Every body is a learning body.. no matter how seasoned you are, you will make some mistake at some point. Your job is to notice the errors and not do them next time. I never messed up body post holes untill my last body... and since i hadent learned from any previous mistakes, i screwed up a body.
I also learned on a past body to score white Faskolor paint with an x-acto before removing the mask, otherwise some of the white paint pulls up with the mask.
I believe everyone can become a Pro painter, even with cans. Just take your time, and do your best. Learn something from each body.
Also try a different scheme for each body. I would like to thank Bob H. for keeping me from doing this... It made me learn new things instead of doing what i'm used to..
Troy
RCTech Member #2
The postings and views expressed on this site are my own and do not necessarily reflect the positions, strategies, or opinions of any company I may be employed by.
TSR6 is offline   Reply With Quote
Old 10-25-2001, 03:27 PM   #25
Cutting a body is easy. I make sure I can see the cut line - either highlight it with a sharpie (fine line) or just a visible line in the lexan. Use a new x-acto blade and score on the cut line and just carefully snap on the line.
When using masking tape or liquid mask try to avoid cutting too deep when cutting your pattern, the body could snap on the line. I don't do a pattern that requires cuts horizontally on the front area for that reason.
slots is offline   Reply With Quote
Old 10-26-2001, 01:44 PM   #26
drummer5's Avatar
There is also a cheaper and easier way of cutting out wheel wells. I got this from a pit tips in rcca. You make your own compass out of lexan. a screw. and an x-acto knife. You take the piece of strait flat scrap lexan and poke a hole in one side on it for the screw and then you mount the body on the car. Then you poke a whole in the wheel well where the center of the wheel nut is and put the screw through it. Then you poke the x-acto knife through at the right spot where u want the height of the well and score it as much as u want.
Here is an example of a body I did when using the method.
Took me about 5 mins to score the line then another 10 to cut them out. And this was the first time I had to cut one out like that.
drummer5 is offline   Reply With Quote
FS: RTR TC4 (Perfect Trans Am Car!) peded R/C Items: For Sale/Trade 2 07-11-2008 10:20 PM
LRP 7.1 ESC - Perfect Condition ! raydog R/C Items: For Sale/Trade 15 12-02-2007 04:52 PM
PERFECT BODY CUT OUT.. Loveless Nitro On-Road 14 10-12-2007 09:10 PM
Are you perfect? Os_powerd_jato Web Links 2 07-08-2007 08:25 AM
Perfect Shocks centax error! Electric On-Road 2 05-19-2005 02:41 AM
